Electric Stunt => Gettin all AMP'ed up! => Topic started by: John Witt on March 21, 2011, 03:30:29 PM
Anyone have a source/good experience to share for left hand spinners to fit our low-pitch pusher props?
John;
Tru Turn at http://www.truturn.com/index.html. Check them out. They make excellent spinners for electric and glow.
And they have fairly fast turn around. A little expensive, but one of the best. y1
Yep, I ordered from them and had noticed they offered left hand spinners. As said above the service was great and fast, had mine in about 3-4 days!
John,
I have used regular electric spinners and even standard spinners (for the 3 blds) and simply squared off the opening to clear the blade root. I use a small 1/4" Dremel sanding drum in my drill press or electric drill to remove the material. One thing you need to do is mark the opening shape and then sand to that. I clean up the corner with a #11 knife and some 120 grit sand paper around a piece of 1/8" lite ply scrap with the edge rounded to get into the corner.
Best, DennisT
