Electric Stunt => Gettin all AMP'ed up! => Topic started by: Larry Renger on February 14, 2013, 08:55:46 AM
At the KOTRC club meeting, Eric Rule showed the laser cut parts for the ET-1 kit. WOW! The coroplast cuts beautifully. No way you could match it by hand. #^
pictures are worth a thousand words. it's show and tell time I think.
Pictures of the planes are available in other threads about it. Do a search. Or if you want a photo of the cut edge, there is nothing to see, it is just a perfectly cut edge, no distortion.
Hi Larry,
That clean, eh?
That's good to know.
thanks,
Dean P.
Hi Larry,
Thanks for that. I was also curious about the edges. I thought that the laser would burn the plastic and the edges would be rough. I know that water-jet cutters do a real good job with coroplast and you can stack the sheets up and blast through a pile of them as well.
Keith R
