  • June 13, 2025, 10:21:03 PM
Author Topic: Viper EL Refit is dust  (Read 2578 times)
Offline RC Storick
« on: August 04, 2011, 07:03:44 PM »
After this years NATS and seeing some hot electric setups I had made the decision to try some electric power. I will be redesigning a purpose built aircraft this year for next year.
In the mean time I choose to retro fit my 08 Viper to electrics. Motor is a E flight power 25. Prop is a 13x 4.5 pusher. Battery is the 3300 MAH Hyperion. ESC is the ice lite 50 and the M9 timer tops it off. I bought 4 battery's and will by more should this work well./ The airplane retro fitted weighs 53 OZ ready to fly. CG is far forward however I never checked it with a full tank on glow.
The wing area is approx 640 and straight forward design. After flying a guys EL plane at the NATS one night in the grass I knew then this is the direction to go. I have tried the same thing over and over for 20 years now and end with the same results. Big airplanes with heaver weights in the nose are not for me. So I am hoping this weekend to try this new set up and revisit a airplane that actually flies with some real performance. PS guys if it has little penetration its tail heavy,don't add weight (you'll end up same as GLO) Shorten the tail. You don't need long moment arms to lever the weight anymore. These engines are close to FOX 35 weight with 60 power.
Picture to follow soon
« Last Edit: August 09, 2011, 07:31:53 AM by Robert Storick »
Offline Jeff Traxler
  • T-Bone
Re: Viper EL Refit
« Reply #1 on: August 04, 2011, 07:45:47 PM »
     Hi Sparky,
          That guys name was Jeff,Glad it helped your decision!!!Welcome to the E side of C/L.Jeff
Online Crist Rigotti
Re: Viper EL Refit
« Reply #2 on: August 04, 2011, 08:06:28 PM »
53 oz for a 640 sq in ship!  You're gonna like it!
Re: Viper EL Refit
« Reply #3 on: August 04, 2011, 10:41:00 PM »
about time!!!!!
let us know how you like it.......and you will!!!!!
Offline RC Storick
Re: Viper EL Refit
« Reply #4 on: August 04, 2011, 10:56:42 PM »
     Hi Sparky,
Well Thanks I guess that how you knew I could fly?
Re: Viper EL Refit
« Reply #5 on: August 05, 2011, 11:10:44 AM »
Pictures man, pictures!
  • T-Bone
Re: Viper EL Refit
« Reply #6 on: August 05, 2011, 11:21:56 AM »
Sparky,
    I actually did'nt know how well you flew,I was looking for another E convert.I did'nt know you were the Stunthanger "Big Cheese" either.Guess we both learned a little something in Muncie!!!Jeff
Offline Dean Pappas
Re: Viper EL Refit
« Reply #7 on: August 05, 2011, 03:06:55 PM »
Yeah! Pictures H^^
  Dean P.
Dean Pappas
Re: Viper EL Refit
« Reply #8 on: August 07, 2011, 08:23:59 PM »
Sparky?
Offline RC Storick
Re: Viper EL Refit
« Reply #9 on: August 07, 2011, 10:16:50 PM »
Crist??
Re: Viper EL Refit
« Reply #10 on: August 07, 2011, 10:18:58 PM »
Offline RC Storick
Re: Viper EL Refit
« Reply #11 on: August 07, 2011, 10:36:26 PM »
Not yet
Offline James Mills
Re: Viper EL Refit
« Reply #12 on: August 07, 2011, 11:57:51 PM »
Sparky,
Are you going to have it ready for Allen's contest or the St. Louis contest?
James
AMA 491167
Offline RC Storick
Re: Viper EL Refit
« Reply #13 on: August 08, 2011, 01:17:37 AM »
Sparky,
James
Its ready now
Offline RC Storick
Re: Viper EL Refit is dust
« Reply #14 on: August 09, 2011, 07:32:43 AM »
Well it was ready now its dust. I crashed it last night.
Offline Darkstar1
« Reply #15 on: August 09, 2011, 08:04:48 AM »
Ouch!
What happened? And were you able to save any of the electronics?
Later,
Evolve or get left behind!
Offline RC Storick
« Reply #16 on: August 09, 2011, 04:30:12 PM »
Ouch!
All of it was untouched
« Reply #17 on: August 09, 2011, 04:38:54 PM »
that sucks!!!!!
any reason for the crash?   not the power system failing.............
Offline Dean Pappas
« Reply #18 on: August 10, 2011, 05:50:55 PM »
Exactly ...
Is there anything we need to know in order to help make the next ship a success?
What, if you got to fly it enough to say, did you get a chance to learn?
Dean
Dean Pappas
