  • July 09, 2025, 06:39:48 AM
Author Topic: KR version 2 timer  (Read 5146 times)
Offline Paul Allen
KR version 2 timer
« on: August 02, 2012, 12:49:55 AM »
Hi guy's
           Ran the Version 2 timer with gain today,I could not tell if it was working.
I ended up resetting the gain to Number 2( I think),then I read the previous post on
the timer ( page 3).So the next plan is to lower the flight rpm and up the gain a bit
at a time.Just need to check I have the gain setting procedure right.OK when in the
setup mode, and I have the 5 flashes and the led stay's off, I press S1 and count two
flashes is that number 2 gain.
Offline Keith Renecle
Re: KR version 2 timer
« Reply #1 on: August 02, 2012, 01:14:31 AM »
Hi Paul, That's about right. After the number of flashes you count by holding S1, then let it go and wait for the 5 flashes to acknowledge the setting. Then it's set. I suggest setting it to its max of 7, lowering the rpm and then you should hear it kicking in a bit in level flight, especially if there is a bit of wind around. Some motors seem to let you hear it more than others but all are doing something. My E-Max 2826 in the new stunter was easy to hear but when I tested a new Pulso 2826/10 on the same settings it was not easy to hear but I could feel it immediately.
From feedback I'm getting, the average setting seems to be 4. Hope this helps. Let me know if you need any more info.
Keith R
Keith R
Offline Paul Allen
« Reply #2 on: August 02, 2012, 01:31:25 AM »
Thanks Keith,did not want bother you, as I know you are going to the worlds.
Offline Andrew Borgogna
  • Andy
« Reply #3 on: August 02, 2012, 10:58:09 AM »
Please feel free to contact me anytime for help with the KR timer/governor.  I have quite a bit of experiance with the timer and work closely with Keith to support the users in the U.S.
Andy Borgogna
abborgogna@hotmail.com
Andrew B. Borgogna
« Reply #4 on: August 07, 2012, 11:44:25 AM »
Keith,
How does the timer work with the prop brake? I have flown ships with no prop brake and in calm wind it is ok, but in high wind conditions it is a BIG problem. I had a ship come around hit the wind and stop. Problem was I still had two feet of air under the plane. Is there a way of using the ESC prop brake with the KR timer?
Best,      DennisT
« Reply #5 on: August 07, 2012, 01:41:53 PM »
Keith,
Best,      DennisT
YES - if the ESC has a brake it will work with the KR Timer. The prop brake is a function of the ESC, if the ESC has a brake (and some still don't) then the Prop Brake engages when the ESC RPM signal stops.   8)
If the ESC is not equipped with a BRAKE function then the KR cannot overcome that.
I also agree that NO brake is NO fun...    :(
« Reply #6 on: August 09, 2012, 02:36:50 PM »
From what it sounds like we could use this timer with any of our existing ESC's by putting them in straight "airplane" mode and turning on the brake (if it has one). Then we can set the rpm for what we want and then set the "gain" to get a little boost when the load comes on. Is that about right?
When we set the gain-boost how long does it hold at the higher rpm? From what was posted it sounds like you adjust the amount of boost rpm by varying the gain - correct?
If all works as described it seems that it should be a step forward for electric.
Best,       DennisT
  • Andy
« Reply #7 on: August 10, 2012, 10:34:31 AM »
Dennis
You are correct in what you said, but keep this in mind unless you need data tracking there is no need for an expensive ESC.  That was the original reason for putting the governor in the timer to help keep the cost of the total system down.  It turns out the KR governor works as well as the governors found in the high end ESCs that we use.  In fact I would say better since the introduction of the vari-gain feature, that's just my personal opinion.  I have never used the brake function even though the ESCs I use all have it, that's not to say I shouldn't use the brake I just never have.  I have found the CC Thunderbird series, the ZTW and the Hobby King ESCs all work just fine with the KR timer/governor, and they cost a lot less than the ICE or Phonenix ESCs.
Andy
Andrew B. Borgogna
« Reply #8 on: August 15, 2012, 10:40:37 AM »
Andrew,
Try the brake, you will like the control you have when landing in wind. On the KR 2 are there more than one rpm set levels? In the CC 45 if you don't run "set RPM" you need to set the %throttle for each of the three run sectors, some feel this is an advantage to be able to add some rpm at the end of the pattern (I like just set rpm and forget it). How do you set for say 9200 rpm?
Best,           DennisT
Offline Jeff Traxler
  • T-Bone
« Reply #9 on: August 15, 2012, 11:13:45 AM »
Hi Dennis,
     I just got a couple of the KR2s with the program stick from Eric at RSM.I set my RPM with the program stick and my tach.Go to the program for set RPM and use the up/down arrows until the RPM you want is achieved and store it.My SV-22 has a EMP 3548-800KV motor,5s 2650 MaH 45c Zippy batteries,Turnigy Trust 45A ESC($16.99 at the US warehouse!!!),and the KR2 timer.The Gov. gain is on 4 and it performs as advertised.I love it and I think you will too.It truly is set it and forget it.
        Jeff
  • Andy
« Reply #10 on: August 15, 2012, 05:16:13 PM »
Dennis
Jeff basically answered the question there is no concept of stages of RPM.  The programming stick work very similar to an NVA in a gas engine.  Stake down the plane or have someone hold it, then using the programming stick start up the motor.  Next using the < > switch just like a needle valve to raise and lower the revs.  I always use a tachometer and record the rev setting.  One thing you must remember if the motor is running above the max RPM based on Kv, voltage, and prop drag you must bring the revs down below that figure.  Or the timer/governor will not enter governor mode and the motor will quit about 15 seconds after start up.  Here is what I do, using the > (up rev carat) I run the motor up until it stops increasing.  This is the region of max RPM based on voltage, Kv and prop drag.  Make a mental note of that RPM setting (or write it down) then using the < (down rev carat) start backing down until you hear the revs (or see it on the tach) come down.  From that point you need to come down from 5% to 20% to build some head space for the governor to work.  If you don't provide the head space the governor will not go into governor mode and it will not run more that about 15 seconds.  Keith can provide more exact numbers but these number do work, I have learned that from lots of testing and flying.
Can you tell me what the weight of your plane is including the battery.  I might be able to suggest a prop and rev setting that will safely get you going.  By the way Dennis Adamisin is also a very good source of information regarding props and rev setting.  He is the person I go to when I need help. y1
Andy
Andrew B. Borgogna
« Reply #11 on: August 15, 2012, 06:54:09 PM »
Andy,
I'm interested in the KR 2 timer for the "boost" 4-2-4. My current setup is an Hacker 30 XL10 (900KV), with a CC45 ESC in "CL" mode with "Set RPM" at 9200 rpm, APC-EP 11 1/2 x 5.5. It has plenty of head room. What I would be looking for is to hit that as the starting setup. Can you dial the rpm in on the programing stick or do you need to set it by trial and error?
Best,    DennisT
« Reply #12 on: August 15, 2012, 07:32:51 PM »
Andy,
Best,    DennisT
Dennis T
Like Trax said you set the KR using the programming stick and a tach.  As you bump it up or down it advances and slows in roughly 100 RPM steps.  Get the one that is closest to your 9200 and you should be good.  Now, to reset it I would not be afraid to hook up the programmer and just bump it up or down one or two clicks, even without using a tach...
As far as adjusting the governor, I do not have enough experience with that to really share much.  I started at a 5, and noticed in the wind that the motor seemed to "buzz" a little in level flight.  Turned it down to 4 and it got better.  Set it down to 3 and the buzz was gone.  Did not try any other settings.
Offline Paul Allen
« Reply #13 on: August 16, 2012, 02:52:10 AM »
Ok, went to the field today with the motor rev's set at 7900rpm, 12x6 APC pusher, Scorpion 780 kv motor, 4S 2800 mha battery, KR2 timer with gain set to 7
as per Keith's suggestion,yes I could here the the motor acting like a 4/2 set up, 5.6 sec lap time, but when the nose went up it pulled up with no drama.
When programming, I found the most important thing is, to count the flashes to confirm you are in the correct parameter.
In OZ
  • Andy
« Reply #14 on: August 16, 2012, 12:22:37 PM »
Paul and everybody else.
Do not expect to see something like a IC 4-2-4 break, that's just not how it works.  Vari-gain is just what the name implies a variable gain for the motor.  A break is a sharp transition from a four cycle to a two cycle.  The Vari-gain adds power as it is required.  The governor/timer is sensing the motor load by monitoring the RPMs.  As the RPMs drop relative to the base RPM setting vari-gain adds back in the difference multiplied bye the gain factor.  So as you pick up the nose of the plane the load increases and revs drop on the motor vari-gain adds back in a metered amount of RPM.  There is no sharp transition to a higher power setting.  I was caught by supprise when I first started testing the vari-gain setup, I really didn't think it was working.  So to prove the point I took the revs down to a point where I could not fly the pattern the set the gain to 5 and believe me the plane flew the pattern with ease.  There was no increase in lap time but when I needed power it was there.  Now regarding the motor hunting or buzzing at the reference RPM, this is dependent on the motor.  As was mentioned, just take the gain down a notch and it should go away.  I set my gain factor to four,  for me that's a good number.  I recommend starting at five and see how you like it.  But again do not expect to see or hear something like a Fox .35 4-2-4 break it just will not happen.
Andy
Andrew B. Borgogna
Offline Igor Burger
« Reply #15 on: August 16, 2012, 01:46:25 PM »
Are you sure? This looks like description of usual governor. I cannot speak for Keith, but as I understood him, he CHANGE gain temporarily under load so the regulator makes a kind of overregulation after signifficant load.
I think Keith is either on way, or packing for Pazardzhik, but may be he will be able to tell what exactly it does. .. Latest when I meet him there :- ))))
« Reply #16 on: August 16, 2012, 02:44:45 PM »
Andy,
I'm not expecting a Fox 4-2-4 sound but if it doesn't add a boost through the maneuvers it is no different then using the ESC governor. From what you describe the KR2 adds boost as you go into maneuvers to pull the ship through without losing speed which is the objective of the 4-2-4 (or a pipe setup). The lap time doesn't increase but the boost is in the maneuver to hold speed. This usually requires that some additional rpm be added which in turn holds the speed as drag increase from control deflections, increase angle of attack and gravity work to slow the ship. Is this what it is doing?
Best,       DennisT
  • Andy
« Reply #17 on: August 16, 2012, 02:46:22 PM »
Igor
I believe what I said is exactly what you said just different words.  Your description does not conflict with what I said, what I said explains how the vari-gain does the job.   I tried to explain how the overregulation kicks in and how much overregulation is applied.  This is very different from a 4-2-4 break where the engine switches between two modes of operation (4 cycle and 2 cycle) based on fuel feed.  Vari-gain is much more sophisticated that 4-2-4.
Remember, I said it takes the differences between the level flight reference RPM and RPM under load (Revs go down) and multiplies that difference by the gain factor and increases the RPM under load by that amount.  It only does this in increase of load, under a decrease in load (Revs go up) such as in a dive the governor takes the RPM back to the reference load basically it uses a gain of 1 vari-gain does not play into to it.
I have had many discussions with Keith regarding how the governor with vari-gain works and I believe this is correct.  Keith if you’re out there and I am wrong please step in and correct me.  The last thing I want to be doing is giving out misinformation.
Take care Igor
Andy
Andrew B. Borgogna
  • Andy
« Reply #18 on: August 16, 2012, 02:48:02 PM »
Dennis
The KR timer/governor with vari-gain most definetly does add a boost, and it's a user adjustable boost.  Read my previous input I hope that helps.
Andy
Andrew B. Borgogna
« Reply #19 on: August 16, 2012, 04:32:20 PM »
Andy,
Thanks that's what we needed. Now the "Wish List" for Keith is to have it sense the decease load (i.e. in a dive or wind push) and have a negative gain adjustment. Then we got it!
Best,             DennisT
  • Andy
« Reply #20 on: August 16, 2012, 05:24:25 PM »
Dennis
Actually he did the testing on that and decided the best way to go was a dual path with gain up and no gain down.  By keeping the reference RPM to a gain of one the prop is acting like a brake coming down hill.  At least I think it works that way.  By not allowing the motor to spin up the prop disk should act like a dynamic break come down hill.  My backround is in electronics not physics, but it seems right to me.
Andy
Andrew B. Borgogna
Offline Paul Allen
« Reply #21 on: August 17, 2012, 03:51:49 AM »
Andrew
          OK, what I was seeing then is the motor hunting, all I can say is it flew better.
I will turn the gain down and see what happens next time out.Does it hurt the motor when
it hunts? I kind of liked the sound.
In OZ
« Reply #22 on: August 17, 2012, 07:51:35 AM »
Paul, Andy,
Looking at Paul's setup is it possible that with the 780 Kv motor it should have either a 5 cell pack or reduce the prop to say and 11 1/2 x 6? Seems this would give a little more head room and you could use higher gain.
Best,        DennisT
  • Andy
« Reply #23 on: August 17, 2012, 09:20:39 AM »
Dennis
You may be right, I will be testing 500Kv motor today for the first time.  To Paul's question no the hunting does not harm the motor.  Like I said set the gain to 4 that should help. I have never had to go below 4 on my setups.  But again all the motors to date that I have tested had Kv's of 900 or greater.  But today I will be testing a motor with a Kv of 500.
Andy
Andrew B. Borgogna
« Reply #24 on: August 18, 2012, 12:00:55 AM »
Hi Guys,
Andy knows the system so well already and has described it really well. Thanks Andy, I'm almsot ready and packed for Bulgaria but still trying to finish some timers to take with me. The differential gain works a lot like Igor's first active regulation where he used a current detector that adds a higher throttle reference to the Jeti Spin esc's governor. My system detects a drop in rpm but adds gain to the governor feedback loop. It does not add a higher reference rpm, just governor gain and only accelleration not decelleration. The only way to get close to the old 2/4 break that can actually slow down the rpm on the downhills, is to use position sensors like accellerometers and gyros. All systems including and especially engine systems have their own funnies that make them less than ideal in turbulence so they are all a trade-off. Holding the rpm absolutely fixed is a good way to fly but then the model slows down in the hard corners. Having a fixed airspeed is not easy to achieve.......ask Igor! It's also very hard to define exactly what we want in fact, but a good constant rpm with a little extra kick when you need it is a good compromise, and does not cost much either.
My system as it is now is really nice to fly with even with the compromises. It sure beats any engine system I've owned when it comes to reliability and being able to get a good stunt setting in any weather. Paul.......I also like the sound of the hunting when the gain is set a bit high. It helps me to know that the governor is working.
Keith R
Keith R
  • Andy
« Reply #25 on: August 18, 2012, 03:09:26 PM »
Well yesterday and today I tested the system with a 60 size motor with a Kv of 620 (for some reason I thought it was 500 yesterday) and at a couple of different RPM settings it did not hunt at all.  Again I set the gain to 4 and the setup flew quite nice even with a wood prop off the LA .65.
Good to hear from you Keith, when it comes to the KR governor/timer you are the last word on everything.  It's the only timer I fly with, and nobody has given me a sound reason to change.
Andy
Andrew B. Borgogna
  • T-Bone
« Reply #26 on: August 18, 2012, 03:35:18 PM »
Andy,
    Did you use 5s or 6s packs?I have a ship that was given to me that had a PA 75 in it.I am going to install a 4250 650 Kv motor with 6s packs and one of the Turnigy ESC's like I put in my SV 22.This timer of coarse!!It is a semi scale Grumman F9F Panther and it is huge.I think this powertrain will have umph to spare.I will post pics when I get the motor mount finished and installed.
        Trax
  • Andy
« Reply #27 on: August 18, 2012, 06:23:02 PM »
Jeff
I use a 6 cell 3900mha battery and an 85 amp Turnigy ESC.  One neat feature of this ESC is it has an on/off switch.  Cycling the switch has the same effect as unplugging the battery.  So I turn on the ESC and it goes through its boot up with all the beeps, then I switch on the governor/timer and ten seconds later I am flying.  The planes all up weight is right at 5 pounds and it goes over the top with no problem at all.
Andy
Andrew B. Borgogna
« Reply #28 on: August 19, 2012, 07:51:35 AM »
A plane that is 5 popunds!!!!    And I thought I built heavy. H^^
  • Andy
« Reply #29 on: August 19, 2012, 09:37:11 AM »
Doc
I didn't actually build this plane.  It's Top Flite Score, and depending on what day of  the week and who was building it you could get one that would fly on a LA .46 or require a LA .65, oh the beauty of ARFs.  I got one of the latter.  The suprise to me was the electric power system I installed including the battery weighed just about the same and the LA .65 and fuel tank with fuel.  The electrics didn't change the CG at all!  The plane pulls like a freight train, but it does fly fairly well.
Andy
Andrew B. Borgogna
« Reply #30 on: August 19, 2012, 01:10:21 PM »
Hey Doc, you should borrow Andy's Score for a week or two, use it to get you into shape for flying the JUMBO!  VD~  n~  LL~  LL~  LL~
Offline Igor Burger
« Reply #31 on: August 20, 2012, 12:39:39 AM »
Keith R
Exactly, may be I should write about that my old solution which I had in Landres WCh 2008 ... I had a current sensor which can "see" power input to prop. It is enough to measure current, because voltage is almost constant. On base on current I did simply positive feedback to prop.
The theory behind is, that if the prop keeps constant rpm, then any extra drag (in corner, or effect of gravity) will slow down the model and it leads to prop slippage and slippage make induced drag on prop tips, so it means motor current is after all function of that speed difference. Since such regulator knows prop slippage, then it is easy to maintain rpm, so that the original rpm + regulation - slippage still equal to wanted speed. Regulator simply compensates slippage by rpm change. It is positive feedback system, so it should theoretically oscillate, but id does not to the point when the gain is less than slippage, so that the system has still some slowing under load. Exceeded gain will do oscillations.
But this system does just opposite we want in wind - for example if wind is comes from back of the prop (when model turns down from hour glass, or upper corner in squares), it will load the motor and regulator will add power just when I do not want it. That was reason why I needed to switch it off in final flights in Landres in that terrible turbulence day. Now I use accelerometer which can add uphill and brake downhill independently of wind outside so it works even better than 4-2-4 and all those problem with stability are solved (it does not mean that it does not create new problems :- PPP )
I heard Keith is already in Sofia, so I am packing also and see you then, I will show my system to Keith and I will see his in action and we will see what makes what in which conditions :- )))
Offline Paul Allen
« Reply #32 on: August 20, 2012, 03:09:35 AM »
Out flying today,gain now set to 6,can just hear the motor hunt,I like it, so that's where it stay's.
Flight time 6min 17 sec, and putting back 1731mah into Hyperion 4s 2500mha battery,
model is a 48 oz Cardinal profile.
All good.
  • Andy
« Reply #33 on: August 20, 2012, 09:06:02 AM »
Great news Paul.  One thing Eric, Keith and I are committed to and that is helping others.  Igor, always good to hear from you.  You are wealth of knowledge and a master flyer.  Hope you have a great Worlds. :)
Andy
Andrew B. Borgogna
« Reply #34 on: August 20, 2012, 01:43:15 PM »
Hi from Pazardzhik in Bulgaria. Just arrived today thanks to Tania Uzunova and friend Zdravko who showed us the way from the airport and got us settled in at our hotel. I went to see the F2B circles today and there are plenty of trees so this will be "turbulence-deluxe"! I'll try to post some regular updates as everything happens. Have a safe trip Igor.
Keith R
Keith R
Offline Igor Burger
« Reply #35 on: August 20, 2012, 01:48:46 PM »
Thanx Keith, I plan to start tomorrow late evening ... so probably I will come Wednesday evening ... if all goes OK
