  • June 17, 2025, 09:15:31 PM
Author Topic: Zippy Compact batteries????  (Read 1232 times)
Offline Russell Bond
  • Bandolero
« on: April 13, 2013, 09:37:19 PM »
Hi,
Are the Zippy Compact lipos ok as my Thunderpowers don't last too long as they do get a "hammering" in a heavy plane...70oz.
Also, I don't treat them very nice as I charge them when I come home from flying and then they stay charged till I fly next, usually the next week.
If I use the Zippys, I can conserve the TPs for competitions.
http://www.hobbyking.com/hobbyking/store/__21361__ZIPPY_Compact_4000mAh_4S_25C_Lipo_Pack.html
Bandolero
Offline William DeMauro
Re: Zippy Compact batteries????
« Reply #1 on: April 14, 2013, 07:09:46 AM »
I've been using the 2700 ones in my sons Gieskie Nobler and have been impressed. The ones you link you are interesting because of their weight to capacity ratio. I just ordered 4 of these to http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=21413 They are close in weight to the Hyperion's I have been using. I want to try them in my SV22 and my new as yet unfinished Voltron. Price, weight and charge rates may make these a very attractive option to some of the more expensive ones.
AMA 98010
Offline Andrew Borgogna
  • Andy
« Reply #2 on: April 14, 2013, 11:08:42 PM »
Russell
You wrote "Also, I don't treat them very nice as I charge them when I come home from flying and then they stay charged till I fly next".  You do not want to store you LiPo batteries fully charged, this will shorten their life.  The rule of thumb is store them with a charge between 20% and 50% in a cool dry place.  I have used Zippy batteries and they last as long as any of the other sport batteries I have used.  Again do not store them fully charged.
Andy
Andrew B. Borgogna
  • Bandolero
« Reply #3 on: April 15, 2013, 05:11:14 AM »
Hi Andrew,
Yes, I know I'm a very bad boy! n1
I should put them in storage mode but I'm slack and lazy!!!! mw~
Bandolero
Offline Curare
« Reply #4 on: April 15, 2013, 05:03:12 PM »
Russel, I've recently been hamming the living daylights out of a bunch of 3300 6s packs for my f3a model. I'm running 2 packs in parrallel and consistently pulling over 100 amps with the setup (Low voltage, high amperage).
They do come out looking a little puffed but after 20 or so cycles of this abuse they're no worse for wear.
I am however swapping out that setup for an 8s one, running such high amperages to get the wattage is a bit rich for my taste.
Greg Kowalski
AUS 36694
Offline RC Storick
« Reply #5 on: April 16, 2013, 06:23:50 PM »
They also have some motors there that look interesting. Has anyone used any of those say in the 25-40 range?
Offline Curare
« Reply #6 on: April 16, 2013, 07:02:09 PM »
I've used the NTM motors for stuff that I don't really care to much about. They're cheap motors and are used as such.
I'm planning on using an NTM 35 36A on 4s in a 35 sized model soon, will report back on how that goes.
Greg Kowalski
AUS 36694
