  • July 08, 2025, 08:41:55 AM
Author Topic: Jus' Curious...  (Read 1148 times)
Offline Ward Van Duzer
Jus' Curious...
« on: July 25, 2011, 09:30:54 AM »
Anybody know why this little Cherrios donut is attached to my ICE 50 timer cord? Obviously done during construction as the connecter wouldn't fit through the hole!
W.  ???
Re: Jus' Curious...
« Reply #1 on: July 25, 2011, 09:50:16 AM »
It's a ferrite bead, there to prevent RF from escaping the ESC and messing up reception on your 72MHz receiver.
Re: Jus' Curious...
« Reply #2 on: July 25, 2011, 10:12:31 AM »
...and if you carefully fuss with it you can remove it by runnig the connector back through it.
Offline Andrew Borgogna
  • Andy
Re: Jus' Curious...
« Reply #3 on: July 25, 2011, 10:22:37 AM »
Tim and Denny are both correct, I remove them and have had no issues.  But put it back in if you go R/C with the ESC.
Andy
Andrew B. Borgogna
Re: Jus' Curious...
« Reply #4 on: July 25, 2011, 12:07:16 PM »
It doesn't look to me like that particular bead could pass the ESC connector housing.  You could pull the contacts from the housing and then unwind things -- but I wouldn't recommend doing that unless you already knew how or had some spare housings (the little latches on the housing tend to break unless you're very careful about holding them back when you pull the contacts).
Re: Jus' Curious...
« Reply #5 on: July 25, 2011, 12:12:36 PM »
Thanks guys, But noway Jose on the removal by this dum-dum!
W.
Re: Jus' Curious...
« Reply #6 on: July 25, 2011, 01:16:28 PM »
Can one take a cold chisel to the ferrite?
Offline John Miller
Re: Jus' Curious...
« Reply #7 on: July 25, 2011, 01:48:15 PM »
Other than a few grams weight, there's no harm in leaving the bead in place. H^^
Re: Jus' Curious...
« Reply #8 on: July 25, 2011, 02:18:42 PM »
IIRC it's pretty strong stuff -- but if you give it a hard enough whack it'll come loose.
That's a lot of effort for a very little weight, though.
Re: Jus' Curious...
« Reply #9 on: July 25, 2011, 08:16:55 PM »
How much is a gram worth to you?  Are you consistent about what you'll pay?
Dave Adamisin
Re: Jus' Curious...
« Reply #10 on: July 25, 2011, 08:46:59 PM »
Two vice grips.......
Re: Jus' Curious...
« Reply #11 on: July 25, 2011, 09:56:00 PM »
Or maybe one big one.  I'll try to find one of those things that's not in a plastic blob and see what it takes to destroy it.
Offline Keith Renecle
Re: Jus' Curious...
« Reply #12 on: July 25, 2011, 11:48:32 PM »
I just cut the wire, remove the ring and join it with some heat shrink tubing. The wire is usually too long anyway and you normally end up winding it up.
Keith R
Keith R
