  • June 13, 2025, 10:38:12 PM
Author Topic: Timers  (Read 11927 times)
Offline Vincent Corwell
Timers
« on: September 11, 2006, 06:46:16 AM »
Hi all
4S Lipo 2100 TT x2
AXI2826/10
12x6 Black Master prop
Brodak Legacy
55 Ounces
JPM timer
Programmed the timer at home :
40 seconds idle
3 Mins @8000 rpm
2 1/2 mins @9800rpm
charged the batteries, tested twice all perfect , no overheating
At field Sat morn
65seconds idle ?
took off in gusty conditions, circa 8-10mph wind
power was barely enough to keep off the ground
I gues about 5000 rpm, ran 5 1/2 mins did not feel any
boost at 3 mins.
Sat night : fitted ST51 and flew really well Sun morn
I know the power train is able but programming the timer is a pain
have not yet had time to charge batteries and check all again at home
But I reckon I will eventually get it all together
Vincent
Offline tom hampshire
Re: Timers
« Reply #1 on: September 12, 2006, 11:52:02 AM »
Vincent - If the math works but not the power train, you may be trying to pull more current than the discharge rating of the batteries will allow.  10C batteries are unusable for stunt, if this is what you have ebay them to an R/C flyer and buy a 20C pack.  Learned this one the hard (expensive) way.  Tom Hampshire
Offline linheart smith
Re: Timers
« Reply #2 on: September 14, 2006, 06:23:24 AM »
Hi Vincent,
I agree with you about programing the timers until Will Moore showed me how to do it without the motor.
Linheart
linheart
Re: Timers
« Reply #3 on: September 15, 2006, 03:46:19 AM »
Hi Linheart
thank you for that, does that invovle an RC servo?
I read the method for that somewhere, probably in the
instructions that came with the timer
but dont understand how to use this.
be happy to buy
a servo to set up my power train.
Will any Futaba servo do?
Vincent
Re: Timers
« Reply #4 on: September 15, 2006, 03:48:48 AM »
Hi Linheart
beautiful finish on your aircraft by the way
From a kit or is this scratch built?
I would be reluctant to fly a plane that good, still
learning the pattern!!
Thanks again
Vincent
Re: Timers
« Reply #5 on: September 15, 2006, 05:25:21 AM »
Vincent,
You wiil need:
1.  One servo.  (Any kind will do)
2.   One R/C receiver battery pack
3.   Clip board.
4.    Battery charger
See attached photo.
The battery gets attached to the Black side (other side is green) of the JMP timer.
Servo on the other (green)side.
Orient the black wire on the servo and battery as shown in photo or refer to the instructions that came with the timer.  Substituting the servo for the ESC.
See my other post for more information and pictures of this model.
Linheart
linheart
Re: Timers
« Reply #6 on: September 18, 2006, 01:17:09 AM »
Thanks for picture
will see if I can borrow the servo n battery from an RC friend
I am totally CL
I have installed the power train in a profile Cardinal
need to reprogramme the timer next
and check the all up weight
These fora are the inspiration, along with Stunt News,
that prompted me to try out the electric power train
Thanks to our host
and every member, of course
(  As my daughter wedding is in 2 weeks I will be too  )
(  busy to develop much furter until mid October  )
Vincent
« Last Edit: September 19, 2006, 01:11:28 AM by Vincent Corwell »
