  • July 25, 2025, 12:01:38 AM
Author Topic: Jeti Spark Eliminator on Castle ICE ESC  (Read 2079 times)
Offline Peter Germann
« on: October 25, 2012, 03:26:53 AM »
When using the 4 mm Jeti Spark Eliminator Plug with a Castle ICE lite 75A ESC we (me and Uwe Kehnen) have noticed this:
Plug-in normally: No audible spark, ESC cells count beeps are 2 or 3 only (we use 5S) and the motor, after delay, does not start.
Plug in real quick: Audible spark,  ESC cells count beeps are 5 and the motor starts normal.
Thanks for comments
Peter
Peter Germann
Offline Igor Burger
Re: Jeti Spark Eliminator on Castle ICE ESC
« Reply #1 on: October 25, 2012, 03:37:22 AM »
Spark eliminator is not good thing with combination of ESC without switch. When you connect ESC with resistor, it will "see" variable voltage during arming procedure regarding consumption of ESC especially when it beeps. If you connect really quickly, before program starts to check voltage everything is OK.
Usage with ESC with slide switch does not make problems, because ESC waits with arming until switch is on, so there is plenty time to connect it also with resistor. For example Spin ESC do not do anything when you connect battery. Only if you switch on slide switch, it makes 5V, processor starts arming procedure - waits until it sees safe "off" throttle singal and only then it arms itself and then beeps.
« Reply #2 on: October 27, 2012, 03:32:29 AM »
Here is how Castle suggests to take care of the spark issue:
"Peter we recommend a 1 ohm 5 amp resistor to work correctly... You could turn off the auto-lipo detection and use 15 volts for LVC and that would work much better...
Clint Akins
Outside Sales and Support"
rgds, Peter
Peter Germann
« Reply #3 on: October 29, 2012, 09:03:52 PM »
I presume he means that if we turn off auto-lipo detection, we can use a 100-ohm, say, resistor for desparking.
Offline John Cralley
« Reply #4 on: October 30, 2012, 08:27:10 AM »
Igor,   Does this mean that, if you use a slide switch to disconnect the timer until after the battery is connected, the ESC will allow the use of a spark arresting resistor??
John Cralley
AMA 52183
Central Illinois
Offline Igor Burger
« Reply #5 on: October 30, 2012, 02:52:44 PM »
There are 2 problems:
1/ ESC will check battery voltage after connecting battery. If you use resistor, the voltage goes up slowly and ESC can see too low voltage, because it will start before completaly charged capacitors. If you use ESC with switch (ESC with switch, not timer separated with switch) then the processor starts when you switch it on, and you will do it only when battery is properly connected. If you do not have switch and ESC starts checking too early, and you still want to use resistor, then you must switch off battery checking by some setting which depends on ESC firmware ... exactly like guys from CC recommend. Slide switch on timer cannot affect this problem.
2/ ESC will beep after arming. ESCs usually check several things after start and if all is OK, then ESC arms itself and usually beeps after arming. One of those thing to test is also iddle signal from timer. So if you do not have switch, it will start already with battery connecter via resistor and beeping will make voltage drop and it will confuse ESC and push thim to low voltage regime. Slide switch on ESC will prevent this situation because it will allow all tests only when you switch it on with properly connected battery. If you have switch on timer wire, it will not allow making iddle signal and it will also prevent arming and beeping.
Well ... little longer answer, but as you see it is not so simple :- ))) All depends on firmware in ESC, but short answer YES is valid only for ESCs with switch (for example Jeti Spin). If you use switch on timer lead, then the answer is "it depends" and proper solution for CC is in Peters post (the question is if they know that we feed ESC with proper signal already connected with resistor). If you do not have any switch, then I do not recomment resistor without good testing.
« Reply #6 on: October 30, 2012, 07:43:07 PM »
Thanks Igor,
That clears up the problem. If the ESC does not have a switch (almost ALL ESCs except Jeti Spin), then you will likely have trouble using a spark arresting  resister.
John Cralley
AMA 52183
Central Illinois
« Reply #7 on: November 01, 2012, 09:51:13 AM »
initial test:
Auto  Li-Po off
Low Voltage Cutoff set to 15.0 V (for 5S)
Jeti 4 mm Anti Spark Connector
no propeller
No cell count beeps
Startup as usual
rgds, Peter
Peter Germann
Offline Igor Burger
« Reply #8 on: November 01, 2012, 10:07:15 AM »
No cell count beeps
that is important ... so they simply disabled whole startup procedure and problem is solved :- )))
« Reply #9 on: November 01, 2012, 12:39:50 PM »
Peter and Igor,
For those of us not familiar with the Jeti 4 mm Spark Eliminator Plug, just how does it work?? Are the contacts set up so that as you engage the plug it first connects a resistor to charge the ESC capacitors and then as it is further engaged it shorts the resistor circuit so that the ESC is fully connected to the battery (with full voltage)??? What are the ohm and watts value of the resistor????
John Cralley
AMA 52183
Central Illinois
Offline Igor Burger
« Reply #10 on: November 01, 2012, 12:55:32 PM »
yes, connectors are done so that the first contact is with resistor and only then directly, I do it myslef with usual carbon resistor
I do not know what resistor is in the Jeti connector, but I use 10 ohm resistors with wires (not smd)
http://www.jetimodel.cz/data_products/images/218/Web-4,0mm.jpg
Online Tim Wescott
« Reply #11 on: November 01, 2012, 02:51:54 PM »
For what little good it does: grrr.
There's no reason for that in a system where software has so much control over things.  All they need to do is wait for the voltage to stabilize, then do their cell count.
Specifying a "do-not-exceed" resistance isn't a bad second place, though, particularly because just about anything you could do with timers could be defeated with a high enough anti-spark resistance.
« Reply #12 on: November 01, 2012, 02:58:59 PM »
That's what I like to hear.  I'm hoping you growl enough to put a CL controller into production.
Online Tim Wescott
« Reply #13 on: November 01, 2012, 03:17:20 PM »
It'd be way expensiver than an RC one just from sheer lack of volume.
Plans are in train (I thought I had started a thread, but I can't find it).  I don't know if I'll get farther than releasing a design into the wild under GPL for the software and one of the Open Hardware licenses for the schematic & PCB design.  But I want to do it just for me, if nothing else.
As an added plus to a DIY thing, if you don't like it you can always change the software yourself :).
