  • June 14, 2025, 01:07:41 PM
Author Topic: Jeti 44 switch  (Read 8051 times)
Offline Dwayne Donnelly
Jeti 44 switch
« on: September 04, 2024, 07:40:58 PM »
Just wondering, since we already use a arming plug it kind of makes the on/off switch redundant, has anyone shorted the switch on a Jeti Spin Pro 44 so it's always on?
Re: Jeti 44 switch
« Reply #1 on: September 04, 2024, 08:19:50 PM »
I don't know where I heard it but I was advised to do that.  I Like the switch and the redundancy, so I kept it.  In a panic or for test arming runs it is much easier than the plug.
Online Crist Rigotti
Re: Jeti 44 switch
« Reply #2 on: September 04, 2024, 08:36:02 PM »
Shorting the switch can eliminate another source of failure.
Online John Rist
Re: Jeti 44 switch
« Reply #3 on: September 05, 2024, 08:50:13 AM »
From a safety stand point the Jeti ON/OFF switch is not OK.  The arming plug removes all battery power from the system making it safe.  With power applied the ON/OFF switch could fail or something could short or -------.  Anyway, as stated before, shorting out the ON/OFF eliminates one possible failure point.  A well designed arming plug is all you need.
Re: Jeti 44 switch
« Reply #4 on: September 05, 2024, 11:34:54 AM »
And a well placed one.  Finding and pulling an arming plug with the motor running is not my idea of a safe thing to do.  A properly place switch that the helper can quickly flop off can save a lot of grief.  Most of the arming plugs I have seen are not in the most accessible place in an emergency.  Even more so on a profile where there is no true
arming plug.
Online Igor Burger
Re: Jeti 44 switch
« Reply #5 on: September 05, 2024, 12:51:00 PM »
It is necessary to understand what an arming plug is and what that switch does. They are NOT interchangeable. While the arming plug disconnects the battery from the system and works like a switch to prevent the unwanted running of the motor, the slide switch works as an on-off switch for powering the timer only. An ESC with the slide switch in the OFF position is still powered, still able to run the motor normally, and is often used in the OFF position, for example, in twins or counter props. Therefore, it cannot be used as a switch for the motor itself and does not connect power to the motor. Its function is to supply power to the timer and thus execute the timer program from start to end.
Contrary to this, the arming plug is NOT meant for stopping the motor run. A rotating motor acts as a generator, making electricity as a voltage source with an internal resistance of a few milliohms, which is capable of burning what is in its way. NEVER (unless there is an urgent need to stop it due to safety reasons) disconnect the battery connector or arming plug during motor operation, as it can damage your ESC. Use the slide switch instead. It will disconnect power to the timer, and the ESC will stop running correctly after a few seconds.
