  • July 25, 2025, 12:44:52 AM
Author Topic: Inverter generator  (Read 2586 times)
Offline RC Storick
Inverter generator
« on: May 01, 2014, 11:02:35 PM »
Will a Earthquake 800W Inverter Generator  charge my 5s 2700 MAH batteries? If so how many at a time will I be able to do?  http://moreoutdoor4u.com/800wattinvertergenerator11613.aspx
Online Tim Wescott
Re: Inverter generator
« Reply #1 on: May 01, 2014, 11:42:20 PM »
That depends on what charger you use.  It claims to have 700 "running" watts, which means they're not being entirely honest with their power rating.  700W at 120V is just short of 6A (720W would be exactly 6A).  If your charger claims 6A then you're probably barely OK.  If your charger claims 5A or less, then you're probably as safe as houses.
Me, I'd trust just about any brand of generator.  As long as it says "Honda" on it.
Offline RC Storick
« Reply #2 on: May 01, 2014, 11:51:45 PM »
My power supply is 2 1000 watt HP computer transformers for a total of 24 volts. I can charge off a 12 volt supply. I have the http://www.progressiverc.com/icharger-306b.html charger
Specifications
• Maximum charge power capacity: 1000W (at >23V; 500W at 12V)
• Charge current range: 0.05-30.0A
•Discharge current range: 0.05-30.0A
• Input voltage range: 4.5-38V DC
•Maximum discharge power capacity: 80W
•Maximum regenerative discharge: 1000W
•Maximum external discharge power capacity: 1200W at 40V/30A
• Current drain for balancing: <500mA
• Balance accuracy: <10mV
• LiPo/LiIo/LiFe: 1-6 series (up to 12S LiFe in non-balanced mode)
•NiCd/NiMH battery cell count: 1-25 series
•Pb battery cell count: 1-18 series (2-36V)
•Battery setup memories: 10
• Intelligent temperature control: Yes
• PC Connectivity: USB port
Offline RC Storick
« Reply #3 on: May 02, 2014, 12:09:47 AM »
I have a deep cycle Marine battery. I guess I could charge from that and charge the battery with the generator.
Well I checked and my 12 Volt power supply is 575 watts max output. So this will work. It will just take a little longer at the field to charge than with my 24 volt 1150 Watt power supply at home.
« Last Edit: May 02, 2014, 12:27:56 AM by Robert Storick »
Offline John Cralley
« Reply #4 on: May 02, 2014, 07:33:44 AM »
The specs say that it puts out 4 amps at 12 volts so there is your limit.
John Cralley
AMA 52183
Central Illinois
Offline RC Storick
« Reply #5 on: May 02, 2014, 08:38:45 AM »
That is on the 12 volt side. I will be using the 120 volt side.
Online Tim Wescott
« Reply #6 on: May 02, 2014, 11:21:42 AM »
If you really want the charging speed then get another Marine battery and run a 24V rail.
I'm not sure how much more charging speed you'll really end up with -- LiPo charging starts with a constant-current phase that's limited by the charger, but it ends in a constant-voltage phase that's limited by how fast the battery can take up charge.  The only part that you can speed up with more power from the charger is that first part; the constant-voltage phase always happens on the battery's own time.
Offline RC Storick
« Reply #7 on: May 02, 2014, 01:30:37 PM »
Well the reason I am doing this is the battery is so heavy. The generator is lighter. I have 6 TP 2700 5S batteries and if I fly one flight and put that battery on the charger it should be charged before I go through the other 5 and so on. If not I will just have to wait.
So I have a 27DP-DL http://www.autozone.com/autozone/accessories/Duralast-Marine-battery-12-months-free-replacement/_/N-255s?itemIdentifier=107676 for sale for $75.00. Its brand new I have charger 2 batteries with it.
« Reply #8 on: May 02, 2014, 01:31:42 PM »
Sorry, I thought you planned to power your charger from the 12 volt output from the generator. My bad!
John Cralley
AMA 52183
Central Illinois
Offline Kim Doherty
« Reply #9 on: May 02, 2014, 04:05:44 PM »
Remember you should let the battery cool before charging. So you fly one, put that battery aside to cool, fly the next one, charge the first battery, let the second one cool. etc.
Kim.
Offline Steve Hines
« Reply #10 on: May 02, 2014, 11:22:51 PM »
How far is the car from where you are flying. you could charge you car battery. I do this with my travel trailer and a little 650 Honda. Home Depot has a 1500 for about the same price but the weight is 62 lbs. I think you could make it work.
Offline chuck_b24
« Reply #11 on: June 17, 2014, 02:51:13 PM »
Quote from: Tim Wescott
[/quote
EXCATLY!!!!! a little EU2000 the best there is!!!!!!
Offline John Rist
« Reply #12 on: June 18, 2014, 08:23:56 AM »
The only problem with the Honda eu1000i  it is spelled $$$$$-H-$$$$-O-$$$$-N-$$$$-D-$$$$-A.
Honda                      $769 ???
Earthquake 800W       $269  :D
Offline 55chevr
« Reply #13 on: June 18, 2014, 08:37:00 AM »
Depending on the application, the Honda is so quiet it runs at a whisper.  If loud is not an issue there are a lot good generators available for half the price. We use them all at work.
Joe Daly
