  • June 25, 2025, 02:12:37 AM
Author Topic: Does anyone know where to get one of these??  (Read 1713 times)
Offline ptg
« on: May 05, 2012, 05:03:42 PM »
Once upon a time in my travels I picked up one of these prop adapters.   Looks pretty standard but has 2 unique features.
1.   Collet shaft is steel
2.   Collet shaft is tapped for 3mm bolt
Other specs:
Fits 5mm motor shaft
Shaft diameter and thread for prop nut is 6mm
This adapter is a clean, elegant solution for my new plane.  Would sure like to get more of them but can’t remember source.  Anybody know??
PTG
PT Granderson
Re: Does anyone know where to get one of these??
« Reply #1 on: May 05, 2012, 10:54:39 PM »
PTG
Found a listing for a Maxx Products adapter, part #ACC370 that is made for a 5mm motor shaft and has a 6mm prop shaft - hard to do that unless it is in steel?  Unfortunately there are no pix, but you might be able to contact them and get the story.
http://www.maxxprod.com/mpi/mpi-291.html#Prop.%20Adapters
Otherwise, maybe TruTurn?
Offline Igor Burger
« Reply #2 on: May 06, 2012, 01:21:50 AM »
I did such thing myself from scorpion adapter, but actually I have similar on OS max motor, but I am not sure with outer thread ... that inner is m3
Offline Darkstar1
« Reply #3 on: May 06, 2012, 10:20:47 AM »
PTG
I believe thats a 5 mm adapter from a Hacker motor. Depending on the motor that was bought they gave you an
aluminum or steel one. Those adapters have a 6 mm prop shaft because I have one. The OS adapters are a bit larger where the prop goes and you'll find if you tighten a OS adapter they are hard to get off without some kind of modified gear puller. Any website that has Hacker accessories should have them. The first pic is the Hacker . The second is the OS .
« Last Edit: May 06, 2012, 10:53:16 AM by darkstar1 »
Later,
Evolve or get left behind!
Offline Darkstar1
« Reply #4 on: May 06, 2012, 10:51:05 AM »
Dennis,
Tru-Turn only makes aluminum shaft adapters. The one I have fits the 5 mm shaft but the prop shaft is 8 mm but requires the backplate to be reamed to .4375 in and another adapter ring made up to tighten the motor shaft.
Later,
Offline ptg
« Reply #5 on: May 06, 2012, 11:07:56 AM »
Thanks Darrell,
That's the one!  Guess I didn't remember where I got it because it came with the motor (or that's my story and I'm stickin' to it ???).
PTG
PT Granderson
Offline Darkstar1
« Reply #6 on: May 07, 2012, 03:24:22 PM »
Ty,
I modified a Battery puller I got from a auto parts store. Any of the chain stores should have one. It works in a pinch But I would still rather find one that's purpose made. My guess would Snap-on or MAC Tools but I haven't
looked around yet.
Later,
Offline ptg
« Reply #7 on: May 07, 2012, 09:04:17 PM »
Hey Darrell and Ty,
One good turn deserves another.  Here is your collet puller.  It's made by Hyperion.  Comes in two sizes, 5/6mm shaft size and 8mm size.
Cheers,
PTG
PT Granderson
Offline Darkstar1
« Reply #8 on: May 08, 2012, 04:58:00 AM »
Looks good Phil, Thanks.
Later,
Offline Darkstar1
« Reply #9 on: May 08, 2012, 03:37:17 PM »
Ty
Try this web site.
http://www.allerc.com/hyperion-collet-adapter-puller-for-m5-and-m6-adapters-p-2732.html
Just ordered one and It's on the way.
« Last Edit: May 08, 2012, 04:27:57 PM by darkstar1 »
Later,
