  • July 26, 2025, 09:43:01 PM
Author Topic: NAT'S 2013 electric model  (Read 1756 times)
Offline jose modesto
« on: August 03, 2013, 11:05:26 AM »
My 2013 Nat's model
SI-PM Saturn Impact PM
model specs, Wing: Impact Foam wing and Flaps
Stab/Elev: Pattern Master 51 spec sheeted Foam
Fuse: My Impact vacuum bagged composite fuse
Electrics:motor Cobra 3520/14 700kv  E flite 32
Controller: Castle ice 50
Timer Hubin
Batt: sky lipo 3000 Mah
model weight at home 70.5 Nat's 71.5
Model finished with dope,basecoat auto colors with acrylic lacquer top coat.
Nats story to come.
Jose Modesto
« Last Edit: August 03, 2013, 01:04:55 PM by jose modesto »
Re: NAT'S 2013 electric model
« Reply #1 on: August 03, 2013, 11:06:49 AM »
Add Photos
jose Modesto
« Reply #2 on: August 03, 2013, 11:08:45 AM »
add photos
Offline linheart smith
« Reply #3 on: August 03, 2013, 11:32:52 AM »
I like it Jose.
Front mount motor.  That is how I mount my motors.  Two retrofits from IC so far but next one built from scratch will have front mount.
How do you like the Cobra?  They have three bearings I think.
Linheart
linheart
« Reply #4 on: August 03, 2013, 04:04:40 PM »
Linheart. This model uses a Bob Hunt mount,the mount is attached to my Impact composite fuse. The front mount eliminated the need for a cowl.(firewall mount) so only one opening for fuse the battery hatch.
the cobra worked real well. I used the motor through first round. For second round I used the Eflite power 32
You should talk to Will Moore about his new plane?
Jose Modesto
Online James Mills
« Reply #5 on: August 05, 2013, 08:57:26 AM »
Jose Modesto
How did you do? We had to leave early so I didn't get to watch any of the round.  I know William and Kevin had a good week.  Sorry to hear Sina crashed.
James
AMA 491167
