Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 29, 2025, 08:17:27 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Electric Stunt
Gettin all AMP'ed up!
(Moderator:
Dean Pappas
Indoors again
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Indoors again (Read 1283 times)
Igor Burger
Trade Count:
0
Admiral
Indoors again
on:
November 21, 2007, 08:35:34 AM »
Anyone going to fly indoors this winter?
I already got 4" bellcrank set for indoors. All is only 3g (0.1oz) heavy (light).
and going to rework standard R/C indoor:
http://www.rc-factory.eu/inshop/scripts/detail.asp?itemId=61&level=7
Logged
pete beddows
Trade Count:
0
Ensign
Re: Indoors again
Reply #1 on:
November 24, 2007, 02:14:41 PM »
Hi Igor
as you know from other posts i am converting a icarus yak for indoors what is the measurement from the pivot point to the flap elevator hole on your bellcrank.ie how much travel do i need
thanking you Pete Beddows.
Logged
Igor Burger
Trade Count:
0
Admiral
Re: Indoors again
Reply #2 on:
November 25, 2007, 08:24:55 AM »
It is 4" bellcrank, I will send you one set. Timers are also prepared, so send me please you address in PM, tommorow I put it to post.
Logged
pete beddows
Trade Count:
0
Ensign
Re: Indoors again
Reply #3 on:
December 09, 2007, 08:23:42 AM »
Hi Igor
What size prop and what revs do you set, the motor on mine has 1040 rev s per volt have 8x4 and 9x4 slow fly props , 2 cell lipoly
euros on there way your timer could not be simpler to make and use,
Logged
Igor Burger
Trade Count:
0
Admiral
Re: Indoors again
Reply #4 on:
December 09, 2007, 09:38:06 AM »
I use GWS 10x4,7 at ~4300 rpm in governor mode, on 160-180g models. Battery is 2cell 750mah and I fly 3.5min it is enough for whole F2b pattern with only one lap between figures on 5m long lines. Motor is 1400 rpm per volt. I had also slower motor 950 rpm per volt and I used 3 cell battery ~400mah.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Electric Stunt
(Moderator:
Dean Pappas
Indoors again
