  • July 28, 2025, 08:40:07 PM
Author Topic: Indoors again  (Read 1279 times)
Offline Igor Burger
Indoors again
« on: November 21, 2007, 08:35:34 AM »
Anyone going to fly indoors this winter?
I already got 4" bellcrank set for indoors. All is only 3g (0.1oz) heavy (light).
and going to rework standard R/C indoor: http://www.rc-factory.eu/inshop/scripts/detail.asp?itemId=61&level=7
Offline pete beddows
Re: Indoors again
« Reply #1 on: November 24, 2007, 02:14:41 PM »
Hi Igor
     as you know from other posts i am converting a icarus yak for indoors what is the measurement from the pivot point to the flap elevator hole on your bellcrank.ie how much travel do i need
   thanking you Pete Beddows.
Offline Igor Burger
Re: Indoors again
« Reply #2 on: November 25, 2007, 08:24:55 AM »
It is 4" bellcrank, I will send you one set. Timers are also prepared, so send me please you address in PM, tommorow I put it to post.
Re: Indoors again
« Reply #3 on: December 09, 2007, 08:23:42 AM »
Hi Igor
         What size prop and what revs do you set, the motor on mine has 1040 rev s per volt have 8x4 and 9x4 slow fly props , 2 cell lipoly
euros on there way  your timer could not be simpler to make and use,
Offline Igor Burger
Re: Indoors again
« Reply #4 on: December 09, 2007, 09:38:06 AM »
I use GWS 10x4,7 at ~4300 rpm in governor mode, on 160-180g models. Battery is 2cell 750mah and I fly 3.5min it is enough for whole F2b pattern with only one lap between figures on 5m long lines. Motor is 1400 rpm per volt. I had also slower motor 950 rpm per volt and I used 3 cell battery ~400mah.
