Electric Stunt => Gettin all AMP'ed up! => Topic started by: Ron Vargo on February 08, 2021, 05:37:11 PM
Title: Igor’s instructions on flight timer/Jeti 66 programming (my 1st electric)
Post by: Ron Vargo on February 08, 2021, 05:37:11 PM
Hey guys I bought all this new stuff from Igor for my 1st electric . Every where I’m trying to find info on Programming on Igor’s pages and other places on stunthangar they don’t seem to be working . I need to set up the jettispin 66 with the Jetti box and program the flight controller. I have never set one up.    Any info would be great.  Thx guys
Title: Re: Igor’s instructions on flight timer/Jeti 66 programming (my 1st electric)
Post by: Howard Rush on February 08, 2021, 07:01:08 PM
Here's some stuff:http://maxbee.net/downloads/downloads.htm
Here are my settings.  These are for a 10-pole motor and 6S battery. If this makes the prop turn backwards, set Rotation to Right.  Target throttle is whatever you need to get the speed right.  Increasing it makes the airplane go faster.  I'd start with sensitivity = 0, then use a nonzero setting when the airplane gets pretty close to being in trim.
Post by: Peter Coates on February 09, 2021, 05:38:26 AM
If you bought your stuff new from Igor then it is already programmed by him.
After a few flights you may wish to make adjustments to suit your own preference.
Otherwise go with his settings and they will get you flying safely
Post by: Ron Vargo on February 09, 2021, 05:59:32 AM
Thx guys........ I appreciate your reply
