  • June 16, 2025, 09:19:46 PM
Author Topic: AXI 2826/10 * Jeti Master Spin 44 ESC - > Best Plan  (Read 1432 times)
Offline José Almeida
« on: October 10, 2014, 08:39:09 AM »
Hi guys.
Following your experience, someone can help me to choose the best model to use the AXI 2826/10 with Master Spin 44 Jeti ESC?
What is the best weight?
I have lots of plans and I am a very big indecision.  HB~>
That's what you sometimes have plenty to choose from  ???
Thanks in advance  :)
José
Offline NED-088
    • Heartstrings
Re: AXI 2826/10 * Jeti Master Spin 44 ESC - > Best Plan
« Reply #1 on: October 11, 2014, 03:17:22 PM »
Anything that previously would have been flown with a .35 or .40
I tried something that earlier had a ST 51 in it and as a result, it was underpowered above 45 deg.
Only adequate in perfect weather (then even better than the Tiger) but for anything else, not enough.
Max prop for this motor is a Graupner 12,5 x 6
« Reply #2 on: October 12, 2014, 12:55:21 PM »
Hi NED!
Thanks for your reply.
My idea are may be the same. This is why have lots of doubts, if it will be in .46 light planes too ???
But allways happen with any 4S bateries independent the C?
José
