  • July 17, 2025, 06:04:16 PM
Author Topic: Need help with programing Jeti ESC with the Jetispin box.  (Read 1002 times)
Offline linheart smith
« on: February 21, 2013, 07:46:08 AM »
I have purchased a Jeti Spin Pro 44 and the Jetibox to program it with.  Using the included manual and a instructional video on you tube () I am well on my way to understanding how to program my new ESC.
Now comes the Snag.  Under parameter "operational mode" you should be able to select "aircraft".  However "aircraft" is not selectable.
Please help.
Linheart
linheart
Offline Igor Burger
Re: Need help with programing Jeti ESC with the Jetispin box.
« Reply #1 on: February 21, 2013, 07:53:12 AM »
and what you see there? what are possibilities to choose from?
« Reply #2 on: February 21, 2013, 08:06:05 AM »
Hello Igor,
Operational mode:
Normal
Fast Response
Constant RPM
Const RPM Auto
Linheart
linheart
Offline Igor Burger
« Reply #3 on: February 21, 2013, 08:20:24 AM »
aaa yes yes ... "PRO" version has "normal" instead of aircraft ... I think they show nonPRO version
here you can see whole menue:
http://www.jetimodel.cz/data_downloads/108/spin_pro_schema-de-en-cz-2012.pdf
« Reply #4 on: February 21, 2013, 08:33:10 AM »
Igor<
Would you list the parameters you program your Jeti ESc?
Linheart
linheart
Offline Igor Burger
« Reply #5 on: February 21, 2013, 08:39:36 AM »
I do not use PRO version, I did not find good settings, but I can evening list parameters for normal version, but important points are:
barke: hard
heli 3D mode
number of poles and rpm from - to regarding prop and motor
sensitivity 1
and all time parameters are on FIX from 1,25 to 2,0 ms
Offline Igor Burger
« Reply #6 on: February 21, 2013, 08:43:03 AM »
I knew it is somewhere written:
http://www.netax.sk/hexoft/docu/iAccTimer_en.pdf
go to end and you will see spin nonPro paprameters
