Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
July 13, 2025, 07:28:04 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Electric Stunt
Gettin all AMP'ed up!
(Moderator:
Dean Pappas
Hypothetical Power System
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Hypothetical Power System (Read 1019 times)
David Hoover
Trade Count:
0
Commander
on:
February 24, 2013, 04:58:15 PM »
Based on various rules of thumb that I've picked up from this forum I've worked up the following power system parameters to power a 65 oz. plane using a 770 kV motor.
Peak power required = 715 Watts
Number of cells = 5
ESC current rating = 50A
Battery capacity = 3300 mAh
Expected battery weight based on power required = 230 grams approximately
Does the above make any sense at all or is it right out to lunch? Comments? Anyone? Anyone?
Logged
Best, Hoovie
John Cralley
Trade Count:
0
Admiral
Re: Hypothetical Power System
Reply #1 on:
February 24, 2013, 05:17:28 PM »
Yep, it makes sense although you don't state what particular motor you plan to use (just the KV).
I suggest that, if you have not yet done it, you go through the "list your setup" sticky thread at the top of this forum. You will likely fine listings for models in your ballpark. Some most likely using 4S and some using 5S batteries.
Logged
John Cralley
AMA 52183
Central Illinois
Tim Wescott
25 supporter
Trade Count:
0
Admiral
Reply #2 on:
February 24, 2013, 05:29:42 PM »
Unless the motor contemplated is dramatically less efficient than the usual, I don't think it matters much for the capacity calculations.
It may matter as far as motor longevity goes, though.
Logged
Dean Pappas
Moderator
Trade Count:
0
Admiral
Welcome to the Stunt Hanger.
Reply #3 on:
February 24, 2013, 05:34:21 PM »
Hello David,
Yes, and a 3000 mAh pack will almost certainly do, as well.
With some experience on that airplane, you may find lighter, smaller capacity batteries that will work, so don't buy all your batts up front.
take care,
Dean P.
Logged
Dean Pappas
Dennis Adamisin
2019 supporter
Trade Count:
0
Admiral
Reply #4 on:
February 24, 2013, 05:42:41 PM »
Nice bit of calcuations, some other ideas:
* KV x voltage --> RPM. you want to run around 70%-75% of the available RPM with nominal voltage. With 770 kv you can run 4S and a 6 pitch, or 5S with a 4.5 pitch; either can work, you just need to decide where you want to go.
* Also 5Sx3300 mah is going to weigh quite a bit more than 230g.
* John C gave tood advice, go to List your set-up", I think you will find systems of comparable power range are using either 4Sx3300 or 5Sx2700
Logged
David Hoover
Trade Count:
0
Commander
Reply #5 on:
February 24, 2013, 05:51:36 PM »
Sorry, I meant motor weight, not battery weight. And I reread that post at least three times before posting!
Logged
Best, Hoovie
Crist Rigotti
25 supporter
Trade Count:
0
Admiral
Electric - The future of Old Time Stunt
Reply #6 on:
February 24, 2013, 05:59:33 PM »
David,
Here is a spreadsheet and article I published in Stunt News a year ago. It'll figure everything you'll need based on the circle ready airplne weight. Works very well.
Logged
David Hoover
Trade Count:
0
Commander
Reply #7 on:
February 25, 2013, 07:59:55 AM »
A big thanks to everyone who weighed in on this. You've been immensely helpful.
Logged
Best, Hoovie
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Electric Stunt
(Moderator:
Dean Pappas
