  • June 13, 2025, 03:33:58 AM
Author Topic: Question for Dean on Battery discharging and charging  (Read 1073 times)
Offline Tim Stagg
« on: April 03, 2011, 06:12:24 PM »
Dean,
I recently bought some new Thunderpower V2 3300 5S to run use on my T33 stunter.
I set the hubin timer to 2 minutes 45 seconds to see what the half "MaH use" would be for a normal 5 minute 30 second flight time, and so not to damage the battery by over discharging them. After dialing in the proper lap times, triming etc with the APC 13-4.5 prop, the amount of milliamp's I am replacing according to the charger is on an average 1480 for the 3 batteries I am using.
I have several questions:
1. How accurate is the reading that I am getting from my charger (ElectriFly Triton) on the replacement amps??
2. The charger seems to get to (5S) 21 volts pretty quickly, say around 1200 replacement milliamp's and then spends the next 300 Milliamp's and say 15 minutes cycling up and down a few tenths until it says it is completely charged, What is it doing during this time, balancing the cells??
3. I am trying to stay at 70-80% discharge, but if I go with the full charge cycle the charger indicates it is replacing I am more like 90% if I were to fly a whole pattern.
4. Could I twist in some more pitch and lower the RPM to save amps, or would the extra pitch pull more, even at a lesser RPM??
5. Based on what I have stated do you think I am likely to over discharge that batteries if I make a full flight??
6. What other info to you need to determine?
Lots of questions I know but I am frustrated.
Tim Stagg
Offline John Cralley
Re: Question for Dean on Battery discharging and charging
« Reply #1 on: April 03, 2011, 08:25:57 PM »
Dean,
I set the Hubin timer to 2 minutes 45 seconds to see what the half "MaH use" would be for a normal 5 minute 30 second flight time, and so not to damage the battery by over discharging them. After dialing in the proper lap times, triming etc with the APC 13-4.5 prop, the amount of milliamp's I am replacing according to the charger is on an average 1480 for the 3 batteries I am using.
I would guess that your charger is reasonably accurate.
Yes, the charger is gradually balancing the battery cells.
Do you have a "Whatt Meter," if not, then it would be worth while to get one and check the amps you are pulling with various prop and rpm combinations.
Possibly, but set the cutoff voltage in your ESC rather high just in case to be on the safe side.
You don't tell us what motor and ESC you are using. How much does the plane weigh ready to fly??
It is possible that a bigger battery is in your future.  ;D
I'm not Dean. Sorry about that.
John Cralley
AMA 52183
Central Illinois
« Reply #2 on: April 03, 2011, 10:40:52 PM »
Dean,
I would expect the reading to be accurate -- but the charge needed after half a flight may not be half the charge of a full flight.  I couldn't say for sure, not being steeped in LiPo lore -- but in general, battery charging isn't a simple science.
I'd try a four minute flight, and see how things trend.
That's a normal charge profile for a LiPo, even without the balancing.  They can only accept charge so fast, and that's reflected by the charge current tapering off.
If that's really true, then you just need bigger batteries.
Good question (and what motivated me to answer).  The motor/ESC combo is going to be somewhat less efficient; depending on how much extra pitch you use the prop may be more efficient, and may be worse.  If there's improvement it'll probably be slight -- but engineers live to be surprised, so it doesn't hurt to give it a whirl.
What might give you more efficiency is if you lower the RPM, and increase both pitch and diameter.  If you take two props generating the same thrust, then in general the bigger one will be consuming less power.  How this translates when you throw all the stunt variables at it---I don't know.
Running a battery down to 90% once isn't going to hurt it terribly much.  It's doing so over and over again that wears it out fast.  Perhaps the best thing to do is just go for a full flight, and see how the plane performs.
Take what I say with a grain of salt---I'm an electronics engineer with aerodynamic pretensions.  The proof is in the pudding, which means you've got to 'speriment. a bit.
Just for chuckles, make sure that you don't have any obvious problems.  Nothing rubbing the motor case, no bad bearings, prop on frontwards, connections tight, ESC good, etc.  I couldn't count the number of working days that I've wasted over my career looking for design problems when the fault was in a broken part.
Offline PerttiMe
« Reply #3 on: April 03, 2011, 11:52:20 PM »
It is filling your pack to the brim.
When you are getting close to full capacity, the pack cannot take a lot of current (Amps), without raising the pack voltage, but it can take a little. So the charger keeps reducing the charge current until the pack is really full.
Offline Dean Pappas
« Reply #4 on: April 04, 2011, 12:55:01 PM »
Hi Tim,
Seems to me like you've already received a bunch of good information. Let me add my two cents worth ...
Taking your questions in order (but only so that I can digress!)
1) First, i have to assume that you are using the new triton EQ that has the balancer built-in. True or no? As to how accurately it measures the charge put back in, I can't say authoritatively: Electrifly do not even publish a specification for this. On the other hand, I'd be surprised if it wasn't accurate to within just 2 or 3%, just based on the needed voltage measurement accuracy and the moderate cost of 1% tolerance components.
2) The LiPO charge cycle has two distinct stages: in the first, the charger "tries to" supply 21.0 Volts (5S) but it cannot because the adjustable current limit gets in the way. This is the Charging Current setting that you chose for nominal 1C charging rate. Eventually, the pack achieves 21V but it is still charging. The current now begins to "tail-off" from its original limit and the remaining 10% of charge will take maybe one-third of the total charging time. The charge is actually declared complete when the current tail drops to maybe 1/50th of the initial current.
2b) If your charger balances the pack, then balancing ideally takes place during this second phase of the charge cycle.
2c) If the pack is substantially unbalanced, then the first cell will achieve 4.20 (really 4.22 for some chargers) Volts before the entire pack has reached 21.0V. If and when this happens, the charger will (should / must?) "throttle back" to a charge rate that is no greater than the "thieving" or bypass current. In the Triton specifications sheet it is called the "node current". The thieving current is steered around the fully/overcharged cell so that it does not charge any more but the other cells still get charged ... BUT AT ONLY 300 mA! If you were charging your 3000 mA-h pack at 3 Amps before, now you are charging 1/10th as fast. This substantially lengthens the time needed to finish phase 1 of the charge, if the cells are unbalanced more than 0.01 or 0.02 Volts.
2d) ALL balancing chargers on the market do this, and must do so, unless they are built using a dramatically more expensive architecture.
2e) 2C, 3C and 4C charging will lose their time advantage if the cells become unbalanced, and the fastest way to unbalance them is to ... wait for it! ... charge them really fast. The other ways to unbalance them are to run them down past 80% capacity and to get them too hot.
3) Yes, 90% discharge is too deep. You will probably need to use bigger batteries ... but let's not get too far ahead of ourselves.
4) Changing the pitch and running RPM may (or may not!) do what you want. In general, motor efficiency suffers when you drop the running RPM but prop efficiency improves a little. For minimum battery consumption, you want to drop pitch and raise RPM until you barely have enough voltage left at 75% discharge to maintain lap time. (If you have a Castle ICE you'd see the %DRIVE approach 95% just before the clover)
Here we need a whole lot more information from you: plane weight, line length, how draggy is it, motor, ESC, battery and desired lap time.
For starters, get the plane slowed down to the desired lap time. This has a dramatic effect. Then if the results are encouraging, sneak up on the flight time. Also try to trim the wasted time off the end of the flight, and lengthen your walk-to-the-handle delay so that you waste as little capacity as possible. The downside of dropping the pitch as far as possible is that you lose punch in the hourglass/overhead 8 / and clover when you don't have excess voltage available at the end of the flight.
5) Yes! Like I said, slow the lap time first then sneak up on the flight time.
6) I'll say it again, we need every bit of info you can think of. An explanation of why the sky is blue would be helpful too! n~
I think you see from the enthusiasm with which answers have accumulated, that we all want you to succeed, so let's git to it!
Dean
« Last Edit: April 04, 2011, 06:52:04 PM by Dean Pappas »
Dean Pappas
Offline Tim Stagg
« Reply #5 on: April 04, 2011, 08:05:48 PM »
All,
Thanks for all of the input:
I guess I need to do a little more splaining.
Airplane weight 66 oz,
680 wing area
e-flite 32
Prop 13-4.5 APC
Thunderpower 5S V2 3300
Timer: Hubin, Castle (RPM high Gov, 9400 RPM, it says, but I am not sure that is accurate based on the motor 12 pole)
Line lenght: Have to measure for sure, I believe they are 66' handle to centerline of plane
Castle ice lite 50
Plane has a very large profile, with profile wing tanks, and is pretty draggy. My tsunami which this is based off of flies with almost a 1000 less RPMs  for the same wing area and weight. Picture attached
Lap time is 5.2 - 5.4 (I realize this depends on the line length, which i need to measure next time they are out  n~).
I am happy with the lap time, I may start sneaking up on the full pattern time and minimize any waste.
The main reason is I tried to buy 3 good batteries that would fly both my tsunami and this plane. @ 120.00 a piece it starts to hurt to have to buy more larger capacity batteries, but if I have to..... I will, my wife just may yell at me some more......but she most likely doesnt need a reason LL~
Tim Stagg
Offline Dean Pappas
« Reply #6 on: April 05, 2011, 09:28:56 PM »
Hi Tim,
At that weight and 5S you should be fine: using maybe 2.4 ~ 2.6 A-H of capacity.
I would think you are running closer to 10K RPM with a 4-1/2" pitch and 66' of line.
Assuming you have the lap time you want, then bump up to 5 minutes and see where you are at. I think you'll be alright at the eventual 5:45 or so.
What's with the tractor prop in the pictures?
Oh yeah ... love the looks of it!
  Dean
Dean Pappas
Offline Tim Stagg
« Reply #7 on: April 08, 2011, 10:02:44 AM »
Dean,
Did some more test last night, I reduced the indicated RPM by about 200 and I still have good line tension throughout. I flew 4 minutes of the pattern and used an average of 1900 MAH. I think I should be pretty close.
Oh yeah the tractor prop was just for holding the spinner on for the pictures. I am using a pusher now. I also think that none of the airplane was actually glued together at that point.
On another note, I think I will eventually find that his is a fairly calm weather ship. The 10-15 MPH wind last night on all of those flat surfaces really bounces me around and pushes the airplane down on the vertical eight and hourglass. I will fly it in profile this year at Brodak to test in competition.  It looks really cool to me so I dont care if I place or not, but it will be interesting to see what happens.
Maybe I will get lucky with the wind.
Thanks again for all your input.
Tim Stagg
