  • June 26, 2025, 05:05:45 AM
Author Topic: Controller temps and Castle's reply  (Read 3854 times)
Offline Russell Bond
  • Bandolero
« on: November 24, 2010, 03:49:22 PM »
Here is a copy of an email sent to Castle Creations from Bruce Hoffmann about controller temps and their reply to him.
I thought that this would be good info for us "leckies".
To: Castle Creations.
Hi,
I've been using the Ice 50 ESC for the past year in Competition Control Line Stunt models - originally I was using an 'Arrowind' 2832 motor (960kv 14 pole) with a 13 x 4.5" electric propeller but recently have changed to a "Plettenberg" 2510, 930kv 10 pole motor.  I ran both at set RPM's of between 9000 and 9400 using 4 cell batteries of between 3000 and 3700mah's.
I've had no problems with the systems I've operated but have been wondering 'what' the safe temperature range (in degrees Celcius) would be.  I recently checked the logging data and saw that temps. had gone up to about 68 deg C.  Is this too high or in what you would believe to be a 'normal/safe' range - what would the max. safe temperature be?
Many thanks,
Bruce Hoffmann
Australia
Hi Bruce,
 The max temp for the controller where it will shut down is 100C. Though 68C is not too bad, I would still rather see it at about 55C or less.
Which Gov. mode are you using? I entered the information you gave on the motor/pole count & the speed of 9400 into the vehicle information of the Set RPM Gov mode and when I look at the info tab beside the Desired Speed box the percent of throttle used for 9400 is only 75% (on 4s). This is a very inefficient throttle percentage. The gov. will work very well here but will build a lot of heat. I personally like to see this number above 88 & even better between 90 & 93%. I have attached pics so you can see what I am talking about. To get into that efficiency range you would have to enter something around 11000 rpm into the head speed box but with what ever prop your using may not allow it.
Getting the efficiency  just right in control line takes a mixture of the correct Kv, Prop & speed. Just playing with your set up on the Castle Link if I change the speed to 9000 & drop the voltage to 3s you get 96% on the throttle which will run the motor at almost full speed giving the best efficiency.
Hope I haven't confused you but if you can get that % number between 88 to around 95% you will for certain see temps come down.
Just in case your not familiar with the Set RPM mode it basically works the same as Gov. Hi/Lo except you have 3 available speeds that are selectable by a range of millisecond inputs from what ever you have controlling your throttle. The first Desired head speed box is for in puts up to 50% (this is based on Helicopter throttle curves but the millisecond input will work the same) which is 1.1ms – 1.5ms. The second box is selected with a range of 1.5 – 2.0ms & the 3rd box for anything greater than 2.0ms.
Hope this helps & if I can be of further assistance please let me know.
Thank You,
Steve Rogers
Castle Creations
Outside Sales & Support
540 N. Rogers Rd.
Olathe, KS  66062
www.castlecreations.com
Direct - 913-948-7582
Cell – 828-246-2170
Bandolero
Re: Controller temps and Castle's reply
« Reply #1 on: November 24, 2010, 05:44:05 PM »
that is quite interesting -but what effect does it have on the motor heat running it at +/- 90%  throttle?
How is the motor more efficient at higher RPM?  seems conflicting
« Reply #2 on: November 24, 2010, 06:49:30 PM »
That depends on how fast they're switching the voltage to the motor, but in general it'll reduce the motor losses somewhat.  How much depends on a lot of details that are up to them and the motor manufacturer, and I don't have any fancy ESC's to put on my O-scope.  It probably has a lot more effect on the ESC heat than the motor heat.
I think he's saying that if the motor speed is closer to max RPM then the system efficiency will be greater.
Someone needs to educate Castle on the peculiar needs of motor control for control line precision aerobatics.
Offline Igor Burger
« Reply #3 on: November 25, 2010, 06:16:31 AM »
No, it is not. If you load the motor to its best efficiency, and then you throttle it down, you will come to overloaded configuration (means on side of too high copper loses, not too much power). It is because motor runs at low rpm during powered part of PWM - means as overloaded with lower than best efficiency and still consumes some energy because of iron loses during switched off part of PWM.
Means if motor runs unloaded at higher that best efficiency rpm, throttling him down will improve it. But out actual motors has relatively wide operating range, so we do not need to worry too much about such tricks. May only if I had to choose between two motors, one with low idle current and another with low resistance, I would choose that with low resistance, that one will be better overloaded.
Other thing is ESC heating. You must understand that PWM throttling is in reality a voltage/current conversion. If you have motor turning a prop at 10 000 rpm for full throttle, it will need some power. If you use twice as voltage, and you will limit rpm by PWM, it will still need the same power (if the efficiency was the same), and half of the current. But the motor still needs previous voltage and current, so the esc in reality converts power from high voltage to low voltage like a transformator.
May be an example: if pwm is 1:1, then the powered period feeds motor by high current, but voltage is low, because of low BMF. Then power is switched off for the same period. So the battery sees current equivalent to half of that high current during the powered period. But motor is an induction (a coil) so the current must continue via diodes in ESC fet transistors, so the real current in motor coil and ESC is HIGHER than current from the battery, and therefore the deeper PWM is, the more thermal loses are in ESC transistors it makes.
Switching rate can improve it little bit, but the higher switching rate also makes higher switching loses, so there is always some optimum which is somewhere between 8kHz and 16 kHz for outrunners we use now.
  • Bandolero
« Reply #4 on: November 25, 2010, 06:34:06 AM »
Eeeuuuw!!!.......My head hurts!!  :'(  :'(
Bandolero
Dave Adamisin
« Reply #5 on: November 25, 2010, 07:30:48 AM »
Perfect!!
Offline John Cralley
« Reply #6 on: November 25, 2010, 11:39:04 AM »
Wow, Igor,
You lost me and at least half of the electric C/L fliers that frequent this forum.  ~^ ~^
I'll read it again a time or two and maybe it will sink in.  ;D
Meanwhile I have a Thanksgiving turkey that is calling!!  #^
John Cralley
AMA 52183
Central Illinois
Offline Igor Burger
« Reply #7 on: November 25, 2010, 02:51:49 PM »
 ;D
... You must draw some pictures and chards and it will come  VD~
Offline Rudy Taube
  • Ret Flyboy
« Reply #8 on: November 25, 2010, 05:23:24 PM »
Thanks for the excellent explanation Igor. If you ever start teaching electronics in school, I would love to take your class. It would be cool to see all your pictures and charts!  8)
While watching my football team beat up on Jone's ego, I wish I was smart enough to come up with a football analogy to explain this, but alas, I am not that smart.  n~
Our modern ESCs are fantastic, magical devices. Think, All pro quarterback Drew Brees + Brilliant engineer Igor Burger in one person!  :!
Below is how I interpret what Igor said ..... I could be wrong, it has happened before ..... just ask my wife! ;-)
The ESC is in the middle with the motor on one side and the battery on the other.
The ESC tells the battery: give me some energy
The ESC sends a burst of energy to the motor and the motor says: oh, that's were the Electric magnetic field is, I'm going to rotate in that direction to line up my magnets with it.
Just before the motor rotation gets there the ESC sends another burst of energy moving the field a little farther, the motor starts to chase this constantly moving target that the ESC keeps moving at VERY fast speeds.
The ESC is constantly asking the battery for more power to send to the motor, and the motor is trying to ask for just the right amount of power it needs to spin it's prop under varying loads at a set RPM.
In our ECL The ESC has a LOT of power coming into it all the time from the battery. "IF" we selected the correct motor, ESC, and battery, Prop etc. for our system then the ESC can just keep sending all this power STRAIGHT through to the motor, with very LITTLE off time during its constant ON and OFF switching to rotate the motor. In this case the ESC does not get too hot.
"IF" we are using a motor that is loafing too much (KV 950 * 14.8V = 14,060 RPM, but we only need 8,500 RPM, 60%) this means that the ESC is sending short ON bursts of power to the motor with (relatively) long OFF times. This means that a LOT of energy is TRAPPED inside the ESC and it has to dissipate much of it inside it's FETs in the form of heat.
This does NOT bother the motor too much, but the ESC does not like it at all, it gets HOT to show us it's displeasure at our poor system selection skills!
Our ESCs are much happier if the motor is telling it "FULL SPEED AHEAD SCOTTY, GIVE US ALL YOU GOT!" Captain Kirk likes it when most of the Beryllium Spheres are being burned up by the motor and not trapped inside the ESC, heating up the whole STARSHIP ENTERPRISE!  n~
....... maybe Igor is right, we may need some pictures and charts?  HB~>
PS: In addition to our modern AC electricity (Thank you Mr. Tesla :-) we have a lot to be thankful for today!  :)
Regards,  H^^
« Last Edit: November 25, 2010, 06:31:49 PM by Rudy Taube »
Rudy
AMA 1667
« Reply #9 on: November 25, 2010, 05:34:50 PM »
nicely put Rudy - it is simple when it comes down to it huh.
now - understanding the below - with the system I run at the moment - 890KV -14.8V = 13,172 - but I am running at 9200rpm only - would it be better to be running a 3s 11.1 volt pack to get me closer to 93% plus throttle?
890 x 11.1 = 9879RPM
or are the reasons to use a higher Voltage more beneficial in any way?
Offline Rudy Taube
  • Ret Flyboy
« Reply #10 on: November 25, 2010, 07:22:40 PM »
Hi Wynn,
Thank you for the kind words. Please keep in mind, Igor is the brains, I'm just a lowly interpreter.  :)
THE SHORT ANSWER:
NO, do not go down to 3S. YES, there are several reasons that we need the higher V. Stay with the 4S
Your setup, as is, will work OK. It will just have an ESC that needs a little more air cooling than a more efficient setup would require.
A better solution than reducing V is to just get a motor with a lower KV. The motor, the ESC, and the Battery will all be a little happier.   :)
LONGER ANSWER:
I think we have to be very careful here. Like many parts of our system, the ESC has it's preferences but we should never let the "tail wag the dog". This narrow topics discussion is really one of making sure that we make changes as needed to keep the ESC within it's safe MAX temp limits of < 55C (<130f).
As Steve from CC pointed out, one way is to make sure we select a motor with the correct KV so that FULL THROTLE is above 75% of max, 90% being close to ideal "FOR THE ESC". This high TH setting is NOT NEEDED FOR THE ENTIRE SYSTEM. We can work well with lower % #s if other factors warrant it, (motor size availability etc.)
Now we need to also keep in mind that the ACTUAL REAL #s are difficult to find without some research and "real life" on board testing/measuring. Our leader, Dean Pappas, has wisely pointed out in past posts that there are several factors that reduce the simple KV * V = RPM formula #s.
1. Our V under load may really be closer to 14.4. And if you are using very low mAh batteries, this V # may even be lower toward the end of the flight.
2. The KV may assume a perfect environment for the motor and the real MAX PRM attainable may be less than published.
3. Other inefficiencies are often at work; heat, resistance increases due to heat, etc., etc.
Dean suggested that we use a rule of thumb of multiplying our MAX RPM # by .8 (80%) to get a "TARGET" RPM for our system. Then use a motor KV that gets us near this #. This .8 # accounts for 10% inefficiency's, and the 10% that Steve suggests (90% of max RPM) that we run below MAX RPM. I have always used a 75% as a target RPM, but I think you get the point that we must correct for real life inefficiencies. Since Dean is smarter than I am, I may start using 80% as my target RPM.  :!
Again, please keep in mind that these are #s trying to reach an ideal. Our modern ECL systems are VERY tolerant of a wide range of different components and still producing more power than we need!
If those new to ECL or thinking about it just use the same components used by people like Paul Walker, and others shown on the "Sticky list" at the top of this forum, they will have no problems. And more importantly, they can just go fly and enjoy the many benefits of ECL without having to know ANY of the stuff we write on these posts!  #^
Regards,  H^^
« Last Edit: November 26, 2010, 08:40:38 PM by Rudy Taube »
Rudy
AMA 1667
« Reply #11 on: November 25, 2010, 07:35:42 PM »
Rudy,
What happened to the head room needed for the ESC in governor mode to work efficiently??? My Castle software tells me when I'm outside the RPM range for proper governor function of my Phoenix ESC (when using Castle Link to set RPM). I can also use software in Demo mode the juggle #s before I commit to a set of components. Am I doing something wrong???
John Cralley
AMA 52183
Central Illinois
« Reply #12 on: November 25, 2010, 07:52:31 PM »
thanks Rudy - I am always looking for better ways to do things - but seems that the way I have it set up at the moment is the right way for our application.
I guess that is what happens when you get the right advice from the start!!!  y1
good topic though - I really enjoy reading this stuff.
« Reply #13 on: November 25, 2010, 10:20:18 PM »
It's kinda been said already, but I'll put in my $.02:  You need head room.  The head room needs to account for battery sag, voltage drop in the motor, and voltage drop in the ESC (yes, the ESC loses a bit of voltage in the transfer -- in fact, that voltage goes to power the heating).  Don't build in enough head room, and even if you've got plenty of oomph at the start of a flight, at the end you'll be out of regulation -- but only when you really need it.  Particularly if your guy from CC was running his simulation assuming that the airplane was at speed, rather than assuming that it was flying slow as it does coming out of a maneuver.
So I'd go with the 75% to 80% head room rule of thumb.  It matches theory when you take all the factors into account, and it matches practice.  If there's anything I've learned from being an engineer for years, you can crank out math all day long, but if you're sitting next to a system that's doing something that disagrees with the math -- the math is wrong.  The guy from CC is doing his math, and coming up with a number that's a lot higher than the practice in this field has found to be effective.  Take your pick as to who you want to believe.
« Reply #14 on: November 25, 2010, 10:51:52 PM »
Ok, here is my super simple aproach to looking at this and what we need, based upon my actual real in hand electric powered airplanes,, Not math
Keep in mind, as the stored energy in the battery depletes during the flight, the voltage falls off as well. with good batteries ( most of the time expensive batteries) the voltage available stays flat until very close to the point we stop pulling power. On less expensive batteries, the voltage drop curve is much faster.
so,,,,
The reason we really need to have substantial headroom is so that at the end of the pattern, when you go into something like the hourglass, you need to have enough voltage and current delivery to still ramp up the torque on the motor to maintain rpm in the climb, If you run to close to the edge,( either to small of batteries, or to high of an rpm for the system) when you get to this point in the pattern, you wont have the drive to fly the airplane the way we want to .
My take, if you run good batteries, you might be able to drive the system closer to the capacity of the battery without problems, with less expensive  batteries, you may want to carry some extra capacity aloft,, and this is a double hit. Cheaper batteries tend to weigh more, then you need a bigger heavier battery besides. Good motivation for buying the best batteries you can justify IMHO
« Reply #15 on: November 25, 2010, 11:39:17 PM »
And the same applies to cheaper motors -- the higher the armature resistance, the less voltage the motor has available to spin with, and to develop torque.  So if all else (batteries, ESC, and motor Kv) are equal, a motor with a lower armature resistance will be able to get by with lower pack voltage.
So: get the best of everything, and you can run less overhead and have a lighter plane (assuming you have gas money to get to the flying field).  Get everything el-cheapo, and you suffer the consequences (while you're enjoying the ability to buy food and heating oil).
Offline Rudy Taube
  • Ret Flyboy
« Reply #16 on: November 26, 2010, 12:24:58 AM »
Wait a min. guys, your ALL correct, BUT we are now talking about three different subjects. Now "my head" is going to explode! n~ ....   ~>
On this thread I (we?) am ONLY talking about ESC efficiency and % of true MAX RPM to keep ONLY the ESC happy. This % has NOTHING TO DO with the % we use for batteries, and motors. They are interrelated yes, but they each have their own % #s. By coincidence they may be similar % #s, but arrived at for different reasons and with different input #s.
It does touch on the motor only because if we push toward the 90% that may make the ESC happy and cool running, we may also be pushing the motor and it's bearings harder than is comfortable on a hot day in our constant high power demand ECL environment. I like to keep as many safety margins as possible and am willing to compromise between system components to do this. That is why I use the 75% of possible MAX RPM using raw published #s. ......  (KV * V)* .75 = Target RPM for flight. This keeps the ESC below it's MAX temp of 130f (with good cooling air flow) while giving the motor a comfortable safety margin below it's MAX RPM ratting.
What Mark said is 100% correct RE: our batteries. We need a LOT of headroom to be safe and be able to have MAX power available at those "peak" times during the end of our sequence (pun intended ;-). It is just a coincidence that our target discharge amount is 75% of max battery capacity. This BATTERY 75% # is really just a compromise between limiting battery size and weight (not dragging around more battery than we need for the mission) AND having a reasonable # of cycles and enough head room to deal with those peaks, and not have a premature battery failure. ...... The electric pylon racers in Europe PUSH ALL the limits, they use almost ALL the battery each flight, their batteries and motors last only several flights and then are replaced. I have seen some hotliners land and you could not touch the battery or the motor for a long time after the flight! ..... I don't think we want to run at these levels, therefore the safe, conservative rules of thumb you see here on this forum. :-)
John:
You bring up a very good point about ESC/Motor RPM "headroom". When we say: TARGET RPM, we are talking about the MAX RPM that the ESC will need the motor to produce during the flight. As seen on other threads on this forum, and on our Eagle Tree recordings, the RPM in gov. mode will often be up to 300 to 400 RPM higher during some maneuvers than the level lap/static set RPM adj. at the timer. THIS measured MAX RPM is what we should use as the 75% to 80% TARGET RPM. This is one of the reasons I use my 75% # when selecting a motor KV, this seems to keep both the motor and the ESC happy and safe. :-)  Remember, this 75% # has 10% factored in for possible inefficiencies already and is still 15% from MAX-MAX that the motor will see at MAX demand. I think this is enough overhead and still a reliable compromise. BTW, if you have to error, I suggest erring on the low side, not the high side of 75-80. Just make sure the ESC gets a good shot of cooling air! ;-)
Using a temp. measuring devise on the ESC may prove helpful during the 1st few flights. There are several, the least expensive is the small units that the RC car guys use. It has a sensor cable that wraps around the ESC, or motor, and gives a MAX readout at the end of the flight. Other methods are even cooler.  8)
I hope this helps clear up any misunderstanding on this?
Again, if there are any "maybe" interested modelers out there still reading this, PLEASE keep in mind that most of this geek talk is a lot of warm air and it is NOT needed info. to fly ECL. Just copy one of the excellent setups at the top of this forum and you will be very successful ECL pilots. You CAN have fun with ECL without getting a headache  n~, honest!
PS: When I use CAPS I am not shouting, I just feel that it helps to have some important words standout if they are more important than others. I apologize if it comes across as being rude, that is not my intent.  :)
Regards,  H^^
« Last Edit: November 26, 2010, 03:36:54 PM by Rudy Taube »
Rudy
AMA 1667
Offline Rudy Taube
  • Ret Flyboy
« Reply #17 on: November 26, 2010, 12:48:53 AM »
I hope everyone reads Tim's and Mark's posts on the importance of using QUALITY products in E-CLPA! I agree 100%. It's just like using a beautiful high quality PA setup from Randy is important in selecting a wet system if you want trouble free, predictable smooth power.
This is probably the most important decision in your E-CLPA system selection process. ...... I would rather give up a daily Starbucks than use low quality ECL parts. Please don't let my SoCal beach friends see this, they deport people from here for much less!  n~
Rudy
AMA 1667
Offline Igor Burger
« Reply #18 on: November 26, 2010, 07:05:46 AM »
Looks like an explosion here  ;D
OK, so I did simple schematic picture of a DC motor. It shows what I mean.
The ESC is replaced by a switch and diode. If the switch is on permanently, motor is powered by constant voltage, it rotates and thus makes a Back EMF which is = actual rpm / kv.
The voltage of battery necessary for that rpm is = BEMF + Imot * ( Ribat + Rimot ) ... this is something we know from rule that voltage of battery must be little higher than Kv of motor dictates. That voltage difference is voltage drop on those two resistors Ribat and Rimot … means resistance of battery and resistance of motor. So that rule 80% is not fixed number, it depends on quality of motor and battery (its internal resistance).
And now comes the trick of voltage /current conversion. The BEMF comes from motor RPM, so does not matter what is the voltage of battery, it is constant since we have constant rpm. Therefore, if we use battery of higher voltage, which would push higher current to the motor winding via those two resistors than necessary to deliver constant power, we must periodically switch off and on that switch in ESC for short time … that is PWM.
The motor coil is an inductance, which keeps current leaking also if switch is off. The current goes via ESC diode.
So if the PWM frequency is high enough, the motor current with high voltage is almost constant and equal to full throttle of that when battery has proper voltage. But the current with high voltage in the motor (and thus in the ESC) is HIGHER compared to current of high voltage battery. That current makes a heat created on internal resistance of ESC FET switch which has also some resistance (not on picture).
(note: this is about DC motor, BLDC motor has more complex switching “H” bridges, and little different diodes inside, which forces that “diode” current back to the battery instead of directly to the motor, but it does change situation only quantitively, it does not change the principle – the diode current stops early after off, but still exists).
That is one part of thermal loses in ESC.
The second part are switching loses. It comes from finite time necessary to open or to close that switch. The transistor has for a while “some” resistance which is not optimally zero (on) and also not infinite (off). Loses are function of power going via ESC. The problem is, that while commutating frequency is ~2kHz, the PWM frequency is at least 8kHz, means throttled ESC has 4 times more switching loses than ESC at full throttle.
All together means that if a producer says the ESC is good for 50A at full throttle then the reality could be much lower in PWM mode or even worse for low throttle.
Offline Bruce Hoffmann
« Reply #19 on: November 27, 2010, 12:29:59 AM »
OMG - such a simple question of the 'Castle' people has generated a huge response!   ~>  When it comes to Electrics I'm a little behind the 8 ball as far as the technical sides of its operation goes...I can 'make' the aeroplane and system work well but as for understanding the intricacies of the 'hows' and 'whys' I regret that I'm left dragging my tongue!
I've created more ducting in my model since I sent the message to 'Castle' - that Russell Bond posted here - however the 'logged' temperature really hasn't changed much.  I flew today in quite warm conditions and immediately on landing used an 'infra-red' thermometer to test the heat of the ESC and also the motor.  Both were in the 45 - 50 degree range - however that's an 'outside' temp of each component - not what the internal circuitry of what perhaps the ESC actually is.
So what it really comes down to is:  Am I safe to continue using the current system or should I be looking at other power plants with perhaps a lower kv rating in the hope that I will be able to produce the same power/torque from the motor and induce less heat in the ESC by doing so? n~
Thanks to all for adding to this discussion,
Bruce Hoffmann
Bruce
« Reply #20 on: November 27, 2010, 01:03:03 AM »
Hi Bruce
I think your set-up is good-to-go - your temperatures seem safe.A little over a year ago - before the ICE came out, those of use flying the Phoenix were blissfully unaware that we "needed" to do anything different!
Offline Rudy Taube
  • Ret Flyboy
« Reply #21 on: November 27, 2010, 02:42:41 AM »
Hi Bruce,
I agree with Denny. Your temps are within limits :-)..... Just fly and have fun.   :)
With that said, your system setup should not be heating your motor. With a little work on air flow you should be able to bring down all your temps by about 5C. This would give you a nice buffer to help you sleep better at night. ;-)
My guess is that it is an air cooling issue for the motor. If you are using a spinner then you have to make sure that the motor is getting good airflow from your front opening, and of course just as important is the exit for the air. If you have a photo of your front end that you can post here it would be a big help in our being able to help you with the cooling issue. That is if you want to try to bring the temps down a little so you have a little buffer? A small "cowl flap" at the leading edge of your exit area can be a big help in bringing down your temps on everything. ..... BTW: What were the "quite warm" air temps you flew in?
How is your battery doing? Can you comfortably touch it after the flight? This is around 45C to 48C which is a happy temp for our batteries.
Please don't worry about all this electric "geek" talk. It's a lot like guys in the wet engine section talking about port timing and metallurgy, etc. ..... nice to know information but totally unnecessary, just bolt in one of Randy's beautiful PA .75s and fire it up, who cares where the bloody ports are!  n~ ... the same is true in ECL, your doing fine and your system flies! 8)
Regards,  H^^
« Last Edit: November 28, 2010, 10:43:53 PM by Rudy Taube »
Rudy
AMA 1667
« Reply #22 on: November 27, 2010, 12:17:39 PM »
If you do the ducting right, you should be able to get a little thrust out of the controller and motor heat.
« Reply #23 on: November 27, 2010, 12:38:51 PM »
I know that applies for a 40-foot wingspan P-51 traveling at 450MPH and cooling a 60% efficient thermal machine producing 1500 horsepower -- but does it apply to a 5 foot wingspan stunter traveling at 50MPH, cooling an 85% efficient electrical machine producing 0.5 horsepower?  The Reynold's numbers are a bit different, as is the amount of waste heat.
Not, mind you, that I'm questioning that someone out there could do the field some real good with cooling studies for stunt aircraft.  If I were a little more nerdy (and didn't have to support kids) I'd do it myself.
« Reply #24 on: November 28, 2010, 03:15:36 AM »
I had a few flights with my model today - much cooler weather however the temps of the ESC appear to be about the same as on the hotter days when the outdoor temperatures were up between 27 & 30 deg c.  I have spoken to Russell Bond and he's looking at putting some ducting on the outside of the fuselage, directing air over the ESC, and also some 'ramping' of the exiting air ducting to help 'pull' the air through the motor/battery compartment.  I'll wait until he tests his model before I start drilling holes in mine!  Anyway, here are a few photos of my model, I will definitely be altering the 'exit' air ducts as advised on an earlier post..
Thanks to all..
Bruce
Bruce
  • Bandolero
« Reply #25 on: November 28, 2010, 03:26:24 AM »
"I'll wait until he tests his model before I start drilling holes in mine!"
I was going to wait till you cut holes in yours!!!!  Hahahaha ;D ;D
Bandolero
Offline Dean Pappas
« Reply #26 on: November 28, 2010, 09:14:11 AM »
Hi All,
I'm gonna stick with my Setpoint RPM recommendation of approximately 75% of Kv * Vbattery.
The good folks at Castle simply do not appreciate that we are trading off heat in the ESC for running characteristics: namely fast load transient response.
Eventually we will get some decent science to show them, but in the meanwhile, there is more benefit, heat-wise, to getting the timing advance set correctly because over-advanced timing is good for nothing but making heat.
Dean P.
« Last Edit: November 28, 2010, 01:48:53 PM by Dean Pappas »
Dean Pappas
Offline Dean Pappas
« Reply #27 on: November 28, 2010, 01:53:57 PM »
Bruce Hoffmann
Bruce, this is a sensible question, and the answer is to improve your cooling air ingress/egress. The motor and ESC want all the cooling they can get.
Too often, we put the ESC in a dead-air pocket and this doesn't help. Changing settings should have a minor effect compared to good cooling airflow.
Best Regards,
 Dean P.
Dean Pappas
« Reply #28 on: November 28, 2010, 10:41:05 PM »
Hi Dean..
I think you have hit the nail on the head...my ESC is - as you say - in a 'dead air pocket'  n1, I'll be installing a scoop so that external air can be directed straight onto it and also do some more work on the exhausting air flow.  Will let everyone know what sort of results I get.  There is another competition next Sunday so I should have the 'renovated' system installed by then except right now its pouring rain - and its expected to do so for the remainder of the week!  Hopefully I'll get a chance to try it out before the comp. day!  (at least I won't need to worry about getting a 'needle' setting like the IC guys do!) ;D
Bruce
Bruce
« Reply #29 on: November 30, 2010, 03:22:22 AM »
OK - I've installed a Scoop on the outboard side of the fuselage (don't know when Russell was going to 'get his finger out' and do the testing for me!  S?P) just in front of the ESC so air should be directed straight onto it.  Also enlarged the outlet in the cowl and made a little 'ramp' to assist the exiting air.  Will hopefully find out sometime in the next few days if the changes have had any positive effect although at the moment its raining heavily and expected to do so for another 5 days or so! ~^ Bruce
Bruce
