  • July 16, 2025, 01:31:36 PM
Author Topic: Hubin Timer Question  (Read 1945 times)
Offline Vincent Judd
« on: May 01, 2018, 03:10:15 PM »
Timer is set for 6 minutes.  Plug battery in and start the motor to check the RPM.  Run the motor for 30 seconds then stop it using the stop/start button.
Once the motor is stopped, will the timer automatically reset to 6 minutes, or is it still counting down from 6 minutes, thus I get a 5 minute and 30 second flight?  I guess the sure way to get the full 6 minutes is to disconnect the battery and then reconnect it.  That should reset everything.
I think I just answered my own question, maybe not.    H^^
Better to be safe, I hate it when the plane quits in the middle of the clover (that can end badly).
Offline Jim Damerell
Re: Hubin Timer Question
« Reply #1 on: May 02, 2018, 04:00:17 AM »
Since no one else is jumping in, I believe the Hubin timer will not restart until power is removed and reconnected.
Offline Mike Haverly
« Reply #2 on: May 02, 2018, 07:00:35 PM »
You don't need to check RPM after you start.  If you want to adjust for speed run 2 minute flights and adjust for lap time after landing by changing the RPM in the timer.  Also, you don't need 6 minutes for a pattern.  Most of us in these parts run 5:15 to 5:25.  Usually we set the "delay" in the timer for 30 seconds, this will end up with approx. 6 minute flight, a little over counting landing.  If you find you have a lot of battery reserve left, you are in luck.  Use a smaller battery.
« Reply #3 on: May 02, 2018, 07:13:04 PM »
Hi Vince
Once you mannually stop the timer you have to disconnect the power again to restart the power on sequence.  You will of course retore your flight duration time setting.
« Reply #4 on: May 03, 2018, 05:10:08 AM »
Hi Mike, thanks for your reply.
The six minute number was purely hypothetical.  Brand new airplane and power system as well as a 3 bladed prop which I've never used before.  Actually the first few flights will be 2 minutes each for trimming purposes. For my first full pattern attempt, I will use 6 minutes just for a margin of safety.  As you suggested, I'll dial it back once I get a baseline on pattern duration.
It's funny you mention the 30 second delay.  I've used that, and I always feel like I'm standing out there forever, waiting for the motor to start.  For competition, I reduced it to 20 seconds and it seems more comfortable for me.  If I'm flying alone with my stooge, I usually leave it at 30 seconds.
« Reply #5 on: May 03, 2018, 05:11:08 AM »
Hi Vince
Thanks Dennis, much appreciated.  Kind of figured that, but wanted to verify.
Offline Jim Mynes
  • Chelsea, ME
« Reply #6 on: May 03, 2018, 06:43:08 AM »
Personally, I wouldn’t jump from a 2 minute flight straight to 6 minutes. That might bring your battery down too low, unless you do some fancy cipherin’ and crunch the numbers real good.
I generally do several 2 minute flights to get lap time and wings flat, then a 2:50 flight with some maneuvers to gauge battery consumption. 2:50 is half of my 5:40 ‘pattern time’, and makes it easy to know if the battery will be sufficient. If I land with >60%, then 5:40 is doable.
I have seen the light, and it’s powered by a lipo.
