  • June 23, 2025, 03:18:41 AM
Author Topic: Brodak Electric Clown Battery Options?  (Read 889 times)
Offline Warren Allred
« on: November 22, 2013, 09:11:01 PM »
Hey Gang,
About to pull the trigger on the Electric Super Clown since Brodak has a lot of the items reduced!
I was wondering if that large of a capacity was needed on the battery?  3300mah?  Pretty heavy...
Anyone know what the typical amp pull is on the Brodak recommended motor and prop?
Thanks in advance!
-- Warren in Missouri
AMA 19909
LSF 8170 Lvl V
Rick_Huff
Re: Brodak Electric Clown Battery Options?
« Reply #1 on: November 23, 2013, 06:45:39 AM »
Warren,
I too recently bought a Super Clown.  I only got in a few flights before the winter set it, but I was averaging 2700mAh for 6 min flights.  I was doing more maneuvers than the pattern, so the 2700mAh number may be a little on the high side, but I doubt you could get away with a smaller battery.
Rick
James_Mynes
« Reply #2 on: November 23, 2013, 06:59:55 AM »
Mine uses right at 2000 mAh for an Old Time Stunt pattern plus about 5 laps. It's a little fast, at 4.8 sec/lap, 57' eye to eye, 5:20 flight time. I think you could get away with a 2700 mAh battery, but will it be that much lighter? My ARF SC weighs 33 oz with battery, you might save a little with a smaller battery.
« Reply #3 on: November 23, 2013, 07:17:42 AM »
Hi Warren
I did the the development on the current edition of Brodak's E-Super Clown so I think I can help you with your question.
Basically the E-Clown is set-up to fly Sport-Stunt speeds and fly for 6 minutes without toasting anything.  The 3Sx3300 pack is up to the task, and it weighs 8.75 oz - total RTF weight of the SC is usually around 30 oz.  To fly with a lighter pack you will have to reduce the flight duration and/or flight speed.
There are a few things to watch for:
* The motor has kv=1500.  That means it is suitable for 3S (11.1V) packs.
* The SC is designed to pocket the battery inside the outboard wing - that is secure, achieves the correct CG and easily changed out.  It also provides the correct tip weight!  The battery pocket is 20mm tall by 50mm wide.  Thus you need to find packs that fit that pocket.
* The Brodak pack is supplied by Arrowind.  I have seen other brands of packs with suitable dimensions, and capacities between 3000 & 3300.  They are all pretty close to the same weight as the Brodak Arrowind - not a lot of weight savings (or penalty) available.
The only weigh (pun intended) I see that you can save substantial weight is to use a much smaller pack and forego flight duration.  You might be able to use a 3Sx2650 if you shorten the flight time to around 4:30.
« Last Edit: November 23, 2013, 09:39:55 PM by Dennis Adamisin »
« Reply #4 on: November 23, 2013, 11:48:28 AM »
Thanks gang for the input!  Looks like the stock setup will suit just fine!  Is everyone happy with the 9x4.5 prop I assume?
AMA 19909
LSF 8170 Lvl V
