  • July 13, 2025, 03:02:13 PM
Author Topic: How to check pack load voltage?  (Read 1073 times)
« on: April 20, 2019, 01:54:45 PM »
Guys,
Ok I fully charged a 4s 2450mah Zippy Compact pack and flew today. This pack is not puffed and took a full charge. However, once in the air I checked the lap time and it was 5.0 sec (59' C to C). This is slow for this ship, it is normally 4.88 sec. I suspect the pack under load is not at full voltage, nothing else has changed with the ESC or timer.
Question is how do I check the pack under load?
Best,   DennisT
Online Fred Underwood
Re: How to check pack load voltage?
« Reply #1 on: April 20, 2019, 04:02:16 PM »
I don't know your Timer and ESC, but some ESC's such as Castle can datalog and give inflight or loaded voltage.
Governor function of the timer or ESC should in general not give your finding.  I can start off at partial charge, so lower that normal voltage, and have normal lap time/rpm.  I might get three 1.5 minutes runs from a battery as initial trim flights, all at the same lap time and can get the same tach reading at a run starting from storage or from full.
Fred
352575
Offline pmackenzie
  • Pat MacKenzie
« Reply #2 on: April 20, 2019, 04:20:01 PM »
Get a wattmeter and a tach, will tell you just about everything you need to know.
https://www.amazon.com/Analyzer-Digital-Balance-Battery-Voltage/dp/B0753DPC2D
MAAC 8177
« Reply #3 on: May 05, 2019, 05:46:22 AM »
OK, WATT meter arrived yesterday. What things can I check with it? How do I use it to check battery condition?
Best,   DennisT
Online Crist Rigotti
« Reply #4 on: May 05, 2019, 07:05:13 AM »
Guys,
Best,   DennisT
Are you flying on a governor?  If so, then pack voltage won't change lap times, especially if taken early in the flight.  Did you time 10 laps and then divide by 10 to get your lap time, or did you time just 1 lap?  I always use the 10 lap method to get an accurate lap time.
