  • June 28, 2025, 01:52:45 AM
Author Topic: how planes fly with electric  (Read 4854 times)
Offline paul winter
« on: October 08, 2013, 01:18:26 PM »
a question for all of you
do we have to build our planes different as we are flying electric and using pusher props etc
i fiind my inboard wing hangs down slightly but not inverted i have tried a wing tab but it has not helped
the question is .......is it the electric causing it
paul
Online Howard Rush
Re: how planes fly with electric
« Reply #1 on: October 08, 2013, 01:53:11 PM »
Impacts (and maybe other airplanes, too) seem to require a higher vertical CG with electric.  I had to move my battery up 5/8".
Offline roy cherry
« Reply #2 on: October 08, 2013, 02:46:11 PM »
hi i was flying with paul on saturday and we were investigating  the trim on his new plane it was apparent that his inboard wing was down but when the motor quit the wing rolled level also on my plane i have a vertical c g ajustable line giude and in the first trimming phase i ajusted it so the wings flew level  but i also noted that my wing rolled out when the the motor quit  i have made up a better jig for checking vertical c g  and low and behold the wing staticly hangs out board down but flys with the engine on with a pusher prop level   is this the effect of gyro becouse i would expect the plane to roll out board with reverse turning       i may have had these problems for years but only now that i have electric i am realy getting to grips with trimming as i am not trying to get an i/c engine reliable to run time afrter time  anbody have a theory      roy cherry
Offline Doug Moon
« Reply #3 on: October 08, 2013, 05:02:23 PM »
Was it the same upright and inverted or opposite when you went inverted?
What you are describing could be torque roll.  Reverse the motor and get a puller prop and see if it rolls the other way.  If it does then you know its torque roll.  If not then you know its Vertical CG.  Knowing which one it is would help you correct it.
If it is torque roll my theory is the electric motor is a constant torque on the frame where the IC is pulsing with each fire and a flywheel effect with the counter balance on the crank shaft is taking some of it out.
A way to correct this would be a tab on each wing to hold it level. I would use a tab separate from the flaps as far out as possible.  When you adjust one up you adjust the other down and so on.  That along with the adjustable guide height and you should be golden.  Just be ready when it quits it will want to roll back into its natural trimmed state in the glide.
Just my thoughts on it...
Others, like Robert says below, are having great success fixing this by moving the battery so it's likely it is just VCG.
« Last Edit: October 08, 2013, 07:57:39 PM by Doug Moon »
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Online RC Storick
« Reply #4 on: October 08, 2013, 06:32:44 PM »
Move the battery up or down for torque roll. However its not torque roll its Gforce
« Reply #5 on: October 08, 2013, 06:53:35 PM »
Paul,
The electric pusher option does bring up some area's that could be refined over IC power. Since the torque on the pusher wants to roll the ship counterclockwise some of the normal trims that get built-in (positive incident on stab, high engine mount to distribute the engine weight vertically) can be looked at and tweaked. With electric we have the advantage of being able to adjust the vertical CG with the battery (you do need to allow the battery holder to be adjustable in both vertical and horizontal directions).
I agree with Robert you more than likely need to lower the battery to level the wings with the pusher prop setup, other option is to put on heavy wheels if you can't move the battery. If you change to a tractor setup you may need to go up.
Best,          DennisT
Offline Dean Pappas
« Reply #6 on: October 08, 2013, 06:56:49 PM »
Hello Roy.
I suspect this is a spiral airflow effect.
By virtue of having a vertically adjustable lead-out (bless you!) you are the perfect guinea pig ... ahem ... I mean researcher for the job.
Try Doug's experiment. I believe it will reverse everything you see.
We see the same thing on a regular basis in RC Pattern. Let me explain.
Plentifully powered Pattern planes trimmed for straight and level flight at full power carry some practically invisible LEFT aileron trim.
Yes, left: the spiral airflow torques the plane to the right!
At idle in a prolonged vertical dive, these planes roll left.
This is a small effect, but when it happens, a change to a smaller diameter prop helps reduce it further.
Paul, try raising the vertical CG like Howard suggested and at least get it to where the tip low upright versus the tip high inverted is the same amount. Then a tab is in order.
As always, it's easy to try the tractor prop and compare. You have to love thatabout e-power.
  Dean P.
Dean Pappas
Offline Doug Moon
« Reply #7 on: October 08, 2013, 08:02:37 PM »
(snip very good info above)
As always, it's easy to try the tractor prop and compare. You have to love that about e-power.
  Dean P.
Yes that is so cool about E-Power!!   :) :) :)
Doug Moon
AMA 496454
Online Howard Rush
« Reply #8 on: October 09, 2013, 01:02:21 AM »
I think the higher vertical CG on electric Impacts applies to both prop directions, but I'm not sure.  Too many sign changes to keep up with.
Offline Peter Germann
« Reply #9 on: October 09, 2013, 04:04:29 AM »
Howard, when trying to quantify torque in level flight, I have found this (Pusher):
My log shows 360 Watt Motor Power In at 9'500 RPM. Assuming that 360 Watts Power In comes to approx. 270 Watts Power Out, the torque in level flight should be 0.27 Nm or 2'753 Gr/cm or 38oz/in. (Approx. 60% more in tight manoeuvres)
Seems to be quite substantial. Is this plausible?
rgds. Peter G.
Peter Germann
Offline paul winter
« Reply #10 on: October 09, 2013, 09:27:45 AM »
hi all thanks very much for your input
i did discuss constant torque with Roy on Saturday and I'm pleased that we have the same opinion
paul
Offline roy cherry
« Reply #11 on: October 09, 2013, 09:57:29 AM »
hi guys my plane has ajustable wing tip flaps  and a ajuster in the main flap i incorparated this item to account for gradual warpage with age all the above has been used to make the plane fly well as suggested i have prepared a tracter prop of the same diameter and pitch and wheight  but i am now being held up by the british autum weather also i have one team selection left to fly so i will leave the trim alone till then        i think that deans suggestion of spraling air flow is probally the anser  i will check so watch thiss space   roy cherry
Online Howard Rush
« Reply #12 on: October 09, 2013, 01:22:13 PM »
Thank you for putting your calculation into our quaint American units of measure, not to mention your accommodating our monolingualism. I felt obligated to do some ciphering.
Yes, I got the same numbers for motor torque.  The rolling moment (torque) change per inch of battery height for my 375-gram battery on 70-foot lines doing 5.4-second laps in level flight is 39 inch-ounces.  Raising the battery 5/8 inch would have changed rolling moment by 24 inch-ounces = .172 Nm.  This made more difference in how the airplane flew than the 76-inch-ounce change from changing the prop rotation direction.  I reckon the swirly-air moment must concel the motor torque pretty well.  Now how does all this vary as speed and angle of attack, and why did I have to raise my battery?
Offline Igor Burger
« Reply #13 on: October 09, 2013, 02:23:24 PM »
hmm ... small question, why you want ballance almost constant motor torque by variable torque comming from variable force comming from centrifugal force minus variable gravity vector? ... we can make almost constant torque from twisted flaps which can easily ballance torque of the motor
Offline Igor Burger
« Reply #14 on: October 09, 2013, 02:26:05 PM »
what exactly did not help? if I read your description, my first try would be twist flaps outwards and add little tip weight ... is that what did not help?
Online Howard Rush
« Reply #15 on: October 09, 2013, 02:54:51 PM »
I moved the battery to cancel the variable torque coming from the variable force coming from centrifugal force (and other line tension sources) minus variable gravity vector.  I don't know why the optimal vertical CG differed between IC and electric power sources.
Offline Igor Burger
« Reply #16 on: October 09, 2013, 03:00:36 PM »
weight of fuel?
and where did you see the difference? wasnt it trimmable with flaps?
hmm .. strange but my model has also CG little up :- ))))
Offline Douglas Ames
« Reply #17 on: October 09, 2013, 04:48:58 PM »
Could it be the (pusher prop's) P-factor?
AMA 656546
« Reply #18 on: October 10, 2013, 04:54:24 AM »
Igor, my log says motor power (watts) being approx. 1.7 times higher in climb. At constant RPM, this should translate into 1.7 times more torque, too.
« Last Edit: October 10, 2013, 06:46:38 AM by Peter Germann »
Peter Germann
Offline Igor Burger
« Reply #19 on: October 10, 2013, 05:38:02 AM »
Igor, my log says motor power (watts) being approx. 1.7 times higher in climb. At constant RPM, this should translate into 1.6 time more torque, too.
psssssst  VD~ ... otherwise someone comes and invents servo controlled compensating trimming tab (actually easy doable as well as electronic rabe rudder) ... and soon we will have flying computer  n~
yes I know ... I mean constant because constnat rpm torque variation is not so large, imagine that my active timer add 1000 rpm uphill :- )))) ... and I still do not feel any need to compensate it any better then twisted flaps do
« Reply #20 on: October 10, 2013, 06:48:15 AM »
[quote author=Igor Burger I mean constant because constnat rpm torque variation is not so large, imagine that my active timer add 1000 rpm uphill :- )))) ... and I still do not feel any need to compensate it any better then twisted flaps do [/quote]
Looking fwd.,  Igor, watching your beautiful thing doing a torque induced snap roll next time it adds a bit of RPM...
Seriously, what I am trying to do is finding the right vertical position, at least for level flight, of my 372 Gr. battery in an in-line type acft. and I thought the roll moment caused by motor torque should be considered when doing this. Unfortunately, I am now running against the "lack of math knowledge" wall, which leaves me sitting here with a big question mark.
rgds, Peter
Peter Germann
Offline Igor Burger
« Reply #21 on: October 10, 2013, 07:18:51 AM »
I think the only way to make neutral model from its concept, is landing gears down, motor and thrust line over the wing with tractor prop 1/ ballancing mass of landing gears by weight of motor and battery 2/ precession of tractor prop by negative moment from drag of landing gears and thrust line over the wing AC ... and that is how my latest model is designed
inline model will work, but it will need several tricks, but I do not see reason to do it if thrust line over the wing works so well
« Reply #22 on: October 10, 2013, 07:34:28 AM »
Yes, Igor, and there is no reason to doubt, obviously... However, as I like experimenting I do consider the building of an electric Shark (pusher) clone which happens to be as in-line as one can be and, from what I've seen so far, might fly a real lot better than I ever will.
So far, compensation ldg. gear mass with the battery suggests to install the battery 37 mm (1.45") above the wing center line. Now, with the motor torque coming in, I am no longer sure whether this is correct.
Peter Germann
Offline Keith Renecle
« Reply #23 on: October 10, 2013, 10:00:38 AM »
Forget about torque..............just do it like the model below  S?P
Keith R
Keith R
« Reply #24 on: October 11, 2013, 08:44:33 AM »
Keith R
Been there, Keith
Peter Germann
Offline paul winter
« Reply #25 on: October 23, 2013, 01:51:48 PM »
avery interesting veiw form Yurli Yetsenko
Yes,  the  torque  of the prop acts to the inverted direction from the
prop rotation. If you will change the prop to another direction of the
rotation, you will feel another direction action. The action of a prop
have 2 separate actions, gyroscopic and aerodynamic  drag of a blade.
Both creates torque to the same direction. When the engine stops, this
torque  disappears.  It is possible to reduce the gyroscopic torque by
the different prop and a motor rotation (see the picture) providing.
However, this modification do not exclude the aerodynamic component of
a torque. The single way to reduce it it is to create the coaxial prop
power plant. 2 ways. The first it is a separate shafts driving by tooth
wheels and a tooth belt for a different way of rotation creating. This
way  do  not exclude the gyroscopic  torque. But with the constant RPM
the  gyroscopic  torque  have "0" action, it acts just when you have
the acceleration or reduce of an RPM. If you fly constant RPM,
you  have  no  action  of  Gyroscopic  moment to the model in straight
flight. (just for active timer with the RPM change it is important).
However,  you  have the Coriolis  torque action, if the model
change  the  direction of a flight from the straight. Every corner the
model  feels  this  action,  also  in  horizontal  flight, because the
horizontal   flight   is  not  straight,  but  round.  If you turn the
rotates bicycle wheel (hold it for an axis both sides from a wheel)
you  will  feel  this  torque  action  and  its  direction.  You  will
understand,   why   sometimes   the   model  reaction is not logic and
different   (asymmetric)   in   some   points of figures, sometimes it
reduce the lines tension, sometimes opposite. More weight of a
rotating  mass,  more diameter, more RPM - more action. That is why so
important  to reduce the mass of a rotation parts. Or to compensate it by
an opposite rotation mass action.
The  third  version  total compensate all torque elements that acts to
the   model   in   flight. But it is heavier and it needs special flat
motors with a low RPM capacity.
Coaxial prop have 20-30 % more thrust capacity. It is an advantage.
I plan to produce this versions for Gee Bee in
future, I need time, money and the energy to do all this faster. I try
to work hard, but my time is limited, this is the question now.
Thank you.
Best wishes.
 Yuriy
