  • July 14, 2025, 09:03:07 AM
Author Topic: How I Assemble a 4S 2800Mah Li-ion Pack From 18650 Cells  (Read 4574 times)
Online Dave Rigotti
« on: December 23, 2022, 02:49:44 PM »
I'm getting some feedback on how I make up MY 4S 2800mah Li-ion packs from 18650 cells that weigh right at 197 grams
It measures 40mm square by 73mm long not counting the wires.
Again..this is how I assemble them.  I KNOW others do it differently.  I KNOW soldering is not recommended. I KNOW someone else may have a better idea/way.  Take it for what's it worth.  This is NOT a "How to". This is a "How I do"......
I use Molicel P28A cells.  These are 2800mah capacity with a 35A max discharge rate.
I solder all battery and wire connections.
I use size "BGA" solder wick for the battery interconnections.
I use 16 gage Castle Creations wire leads terminating to XT30 connectors.
All soldering is done with a 40watt iron and a chisel tip.
1st-I clean each battery terminals with a few swipes of scotch brite and then wipe 'em with a bit of lacquer thinner.
2nd-I pre-tin the cell terminals with a bit of 60/40 rosin core solder.  It only takes a few seconds to achieve an acceptable blob.
3rd-I assemble the 4 batteries into my own designed 3D printed cell holders that allow a slight press fit onto the cells.  The back and front spacers are different from each other as the front requires an opening to allow the 16ga leads and balance tap wires to exit.  They also allow cooling air to circulate between the cells and allows thru the center air flow.    There is also trenches for the interconnect straps and clearance for the balance tap wires.  The cells are only slightly warm after a 5 minute flight consuming @1800mah (@22A average).
4th-I solder 3/4" long pieces of the solder wick to the cells.  2 straps on the back end and only 1 required on the front end.
5th-I then solder the battery leads onto the plus and minus terminals that already has the XT30 connector attached to them. This reduces the chance of a short circuit.
6th-I then solder the balance leads to each cell using the positive terminal "side" where possible. This allows a quicker easier solder operation.
7th-I then get my voltmeter out and verify the balance tap wire sequence and the polarity of the XT30 connector.
8th-I then use medium CA to attach the front and back end caps. These keep the connections safe from shorting on something.
Attached photos show how neat and clean MY assembly is with the 3D printed parts.
That's how I do it.  Now hopefully after 300 cycles on it I'll still be happy with the pack.......
Link to .STL files:  https://www.thingiverse.com/thing:5739042
« Last Edit: December 23, 2022, 03:33:29 PM by Dave Rigotti »
Dave Rigotti
AMA 66859
Chesterland, Ohio
Online Crist Rigotti
Re: How I Assemble a 4S 2800Mah Li-ion Pack From 18650 Cells
« Reply #1 on: December 23, 2022, 04:21:22 PM »
Nice.
Offline Brent Williams
« Reply #2 on: December 23, 2022, 04:38:00 PM »
Clean work!  Thanks for sharing your build.
Online Steve Berry
« Reply #3 on: December 23, 2022, 06:26:02 PM »
Very nicely done.
Now, what is the difference between the 18650 and 21700 cells? Size? Reliability? I'm wondering which I need to see about getting to make my own battery packs.
Thanks.
Online Dave Rigotti
« Reply #4 on: December 23, 2022, 06:41:07 PM »
18650 is diameter by length. 18 dia by 65mm long.
Can you guess what a 21700 cell is??
Probably start your own thread on what cell vs another cell 'eh?
Very nicely done.
Thanks.
Dave Rigotti
AMA 66859
Chesterland, Ohio
Online Steve Berry
« Reply #5 on: December 23, 2022, 06:57:38 PM »
This plane is going to Cuba....um, er....this thread is going on with relevant information (darn hijackers!).
Offline John Rist
« Reply #6 on: December 23, 2022, 07:23:33 PM »
You wouldn't be interested in selling end cap sets?
Online Dave Rigotti
« Reply #7 on: December 24, 2022, 01:41:33 PM »
Check your messages please.
Dave Rigotti
AMA 66859
Chesterland, Ohio
« Reply #8 on: December 25, 2022, 11:10:58 AM »
Hi Dave,  Mr. National Intermediate Champion!!! (hey buddy you earned it and you have bragging rights for about 7 more months!)
NICE WORK! Thanks for sharing your methodical approach to assure you have good solder joints.  Also like the end caps,  I also have a lot of airplanes that could use the 2700's - it is a good size.
The way you made that pack makes me wonder if a 4 across "flat pack" would be viable?  Imagine a pack that could be mounted internally in a profile fuse?  Also looks like a 2x3 cell layout would be a completely viable 6S layout
Question for you and the other Li-Ion pioneers:  Are there suitable cells available around 1800-2200 range?  More important, would they offer important savings in size & weight?  Historically i have used 4Sx2200's in many airplanes.  I have also been driving down the battery sizes on several airplanes, for example using 4Sx1800 (175g/6.2 oz) in the Stuka Stunt and 4Sx1300's (4.8 oz) in the Barnstormer. Li-Ions would seem to offer potential further size & weight savings in smaller packs that they do in the larger sizes.
THANKS in advance
Online Dave Rigotti
« Reply #9 on: December 25, 2022, 11:37:54 AM »
Denny,
Thank you for the Kudos!  Advanced class will be tougher to achieve the identical results, I'm gonna try though!
I really haven't explored other sizes of the Li-ion cell batteries.  The Molicell 18650 4S at 2800Mah and 35A discharge weigh the same as a Thunder Power 4S 2200Mah (200grams).  I KNOW others are using the same cells in a 6S triangular "stick" configuration on 55-62oz stunters with success. The big draw for me is the anticipated 300 cycle useful life OR more.
I have made up a 4S "stick" pack to power my Sullivan starter when I fly my speed events.  It goes all weekend easily without recharging.  And Yes, I drew up and 3D printed the holder and end cap needed to adapt to the starter motor.  I did not bother with 3D printed parts for the battery pack as the use is only a second or 2 for each start and cooling air is not needed. (@35A draw for 1 to 2 seconds).
Dave Rigotti
AMA 66859
Chesterland, Ohio
Online Dave Rigotti
« Reply #10 on: January 05, 2023, 08:09:33 AM »
Dave Rigotti
AMA 66859
Chesterland, Ohio
Offline Dan Bregar
  • Field Marshall
« Reply #11 on: January 21, 2023, 06:44:17 PM »
I saw a guy this summer at my local flying field who had a pack just like this. Amazing ! Hey you're from Ohio. So was this guy.  ;D
AMA 33676
Online Dave Rigotti
« Reply #12 on: January 24, 2023, 08:43:45 AM »
Dan,
Was he as good looking as I am?  You only have 2 choices then!!!
Dave Rigotti
AMA 66859
Chesterland, Ohio
