  • July 15, 2025, 06:18:18 PM
Author Topic: Hint Vents  (Read 1348 times)
Offline Larry Wong
Hint Vents
« on: January 06, 2013, 12:05:28 PM »
My hint is I found somthing some might like to try ....Louver vents, made of light aluminum.. #^  #^
Larry
Offline Larry Wong
Re: Hint Vents
« Reply #1 on: January 06, 2013, 12:06:44 PM »
From Hardware store.
Larry
Offline Jose Luis Oterino
Re: Hint Vents
« Reply #2 on: January 06, 2013, 01:21:44 PM »
I always wanted something like locate an Spanish hardware store ...
that machine or device is this part?
Offline Larry Wong
Re: Hint Vents
« Reply #3 on: January 06, 2013, 02:04:13 PM »
I found this part in the roofing dept. it's a attic vent some just have big louvers this I just happen to see it has small louvers in the vent. real cool looking ... just cut them out and trim to fit.
Larry
Offline Dean Pappas
Re: Hint Vents
« Reply #4 on: January 06, 2013, 04:47:11 PM »
Okay ... that's neat.
The next plane will be chopped and channelled, lowered and louvered ...
later,
  Dean P.
Dean Pappas
Re: Hint Vents
« Reply #5 on: January 07, 2013, 08:47:07 AM »
Thanks... I will try to search...
Offline JohnCallentine
Re: Hint Vents
« Reply #6 on: January 08, 2013, 11:15:39 AM »
I have used similar louvers on my electric stunter. I have a homemade punch that makes 1" wide louvers of any length. I use soft aluminum from offset printing plates.
Re: Hint Vents
« Reply #7 on: January 08, 2013, 05:09:43 PM »
Can you be more specific, John? How do you make these? Especially that belly vent. That is very cool.
Offline Dean Pappas
Re: Hint Vents
« Reply #8 on: January 08, 2013, 09:40:40 PM »
I Like it, John!
How about some more pictures of this very pretty ship ... huh? Pretty please.
thanks,
  Dean P.
Dean Pappas
Re: Hint Vents
« Reply #9 on: January 09, 2013, 01:53:37 PM »
Randy, That "belly vent" is actually on the top and is made from strips of 1/32" plywood slotted halfway thru with a Dremel cutoff disc. They are pretty easy to make either straight or curved. Credit Keith Trostle with the idea.
Offline Les Byrd
Re: Hint Vents
« Reply #10 on: February 08, 2013, 01:14:09 PM »
John, my compliments, very neat, very well executed, exemplary craftsmanship!
Re: Hint Vents
« Reply #11 on: February 08, 2013, 06:12:28 PM »
That's very slick, John.
