Electric Stunt => Gettin all AMP'ed up! => Topic started by: Larry Wong on January 06, 2013, 12:05:28 PM
My hint is I found somthing some might like to try ....Louver vents, made of light aluminum.. #^ #^
From Hardware store.
I always wanted something like locate an Spanish hardware store ...
that machine or device is this part?
Regards
I found this part in the roofing dept. it's a attic vent some just have big louvers this I just happen to see it has small louvers in the vent. real cool looking ... just cut them out and trim to fit.
Okay ... that's neat.
The next plane will be chopped and channelled, lowered and louvered ...
later,
Dean P.
Thanks... I will try to search...
I have used similar louvers on my electric stunter. I have a homemade punch that makes 1" wide louvers of any length. I use soft aluminum from offset printing plates.
Can you be more specific, John? How do you make these? Especially that belly vent. That is very cool.
I Like it, John!
How about some more pictures of this very pretty ship ... huh? Pretty please.
thanks,
Dean P.
Randy, That "belly vent" is actually on the top and is made from strips of 1/32" plywood slotted halfway thru with a Dremel cutoff disc. They are pretty easy to make either straight or curved. Credit Keith Trostle with the idea.
John, my compliments, very neat, very well executed, exemplary craftsmanship!
That's very slick, John.
