  • June 23, 2025, 12:14:08 AM
Author Topic: High rpm test stand motor (25,000rpm ish)  (Read 1848 times)
« on: June 12, 2021, 09:45:38 AM »
I am doing some prop test and need a motor capable of 25K plus rpm. Wondering if it should be and in-runner or out-runner type. I have both 4S and 5S packs for power, likely won't be pulling more than 40 amps and only for short 15 sec run time (just enough to measure thrust and amps). What brand and size should I look at?
Best,    DennisT
Online John Rist
Re: High rpm test stand motor (25,000rpm ish)
« Reply #1 on: June 12, 2021, 09:47:50 AM »
Depends on prop size.  y1
« Reply #2 on: June 12, 2021, 01:42:58 PM »
John,
This is for smaller props 6" diameter and less (1/2A size).
Best,    DennisT
Offline pmackenzie
  • Pat MacKenzie
« Reply #3 on: June 12, 2021, 02:10:44 PM »
Rather than a brushless motor you could use a router, the RPM range is about right.
MAAC 8177
Offline William DeMauro
« Reply #4 on: June 12, 2021, 06:59:57 PM »
Just to kind of give you a baseline, i tested 8" props up to almost 18000 rpm and i was pulling some serious amps. (close to 90 amps) on a 75 amps speed control. I was doing this for 15-20 seconds on a castle edge and a 1400kv outrunner so i could log everything.. if you are just doing a prop test then you can oversize the motor and speed control and hitting 25k should be easy especially if you use a 6s battery. You can adjust the motor and battery once you have the numbers and you know how many amps the prop will pull at those rpm. Remember if it is a bench test your amperage will be higher. Make sure you have a prop capable of spinning that fast without it flying apart too.. I did smoke a few motors and speed controls in flight tests, but i was trying to get a flite steak sized plane to over 100mph for 2 minutes. I think i would have made it as I did get it to the low 90's a few times then kind of got distracted with other things and never went back to it.. There are  many factors to consider so ramp up gradually and watch your numbers. I feel it is doable and most likely has been done already.
AMA 98010
Online Howard Rush
« Reply #5 on: June 12, 2021, 09:38:14 PM »
Rather than a brushless motor you could use a router...
That’s what I do.
Online John Rist
« Reply #6 on: June 12, 2021, 09:54:22 PM »
John,
Best,    DennisT
A Cobra  C-2820/8 Brushless Motor, Kv=1450 on a 5 cell battery should do the job.  Look at the prop chart.
https://innov8tivedesigns.com/cobra-c-2820-8-brushless-motor-kv-1450.html
Any good 60 amp ESC and I would use a servo tester to control the ESC.  such as
 https://www.ebay.com/itm/333879969440?hash=item4dbccc06a0:g:ji0AAOSwlYtgHXzI
« Last Edit: June 13, 2021, 07:58:29 AM by John Rist »
« Reply #7 on: June 13, 2021, 11:13:19 AM »
John,
I order the servo controller, for the motor I looked at what Innovative had to offer, Since I will be testing less than 6" diameter props (likely less than 5.5") this motor looks like it would fit: Cobra CP-2210-2200 Champion Series FPV Race Wing Motor, Kv=2200. I could order two of them and use one for the test stand and use the other for a test ship. What do you think.
Best,    DennisT
Online John Rist
« Reply #8 on: June 13, 2021, 02:47:24 PM »
John,
Best,    DennisT
Looking at the prop chart,  this is a good fit.  The fact that it runs on 4 cells is a +.  Also a 40A ESC should work.
J Rist
