  • June 23, 2025, 10:46:47 AM
Author Topic: Help with RPM setting  (Read 1101 times)
Offline John Castle
  • The Bent Pin
« on: May 01, 2012, 09:55:33 AM »
I am finishing up a Smoothie ARF with the following gear and I have no idea what rpm settings I should program into the speed control.
I will be using 60' lines
This motor-    http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=16231
This battery-  Capacity: 3000mAh - Voltage: 4S1P / 4 Cell / 14.8V - 25C Constant / 50C Burst
APC 12x6 E PUSHER
ICE Lite 50
I realize that some adjustments can be made after flight testing but I need a good safe place to start.
Also I see that some people will trim that prop to 11.5 inches, is that necessary?
John Castle
McMinnville, Oregon
AMA# 589650
Re: Help with RPM setting
« Reply #1 on: May 01, 2012, 02:51:00 PM »
I don't have specific experience with bigger motors, so this is slightly theoretical:
The two things that set your maximum RPM are the fact that you want to maintain regulation throughout the whole flight (as the available voltage from the battery sags), and the fact that you don't want to burn up your controller or motor.
For regulation, the recommendation that you'll see over and over again is to allow for a 20 to 25% drop.  You're starting out with 14.8V and a Kv of 900, which works out to a theoretical full-battery, flat-out RPM of 13320.  Drop that by 25%, and you get 9990 RPM.  Choose an RPM over that, and toward the end of the flight you'll notice the motor sagging in the up-lines, and anywhere else you're asking for lots of power.
For current draw, well, I'm not sure because I don't fly that sized motor -- but I took a quick look at similarly sized motors on the Hobby-Lobby website, and their recommended props seem to be in line with what you're choosing.  Particularly since you're always going to be throttled down a bit, I suspect that you're OK from a current draw standpoint with that prop.
If you can, check the current draw from the battery on the ground -- that's the most current you'll ever draw, and as long as it's less than 50A, you (and your ICE 50) will be happy.
Offline Andrew Borgogna
  • Andy
« Reply #2 on: May 01, 2012, 03:08:49 PM »
I would start somewhere around 9000-9100 and go from there.  For the first couple of flights set your timer short, say 1.5 minutes and check basic trim and lap times.  Anyway it's a place to start.
Andy
Andrew B. Borgogna
Offline William DeMauro
« Reply #3 on: May 01, 2012, 05:44:03 PM »
John,
I agree with Andrew on the RPM setting as a good place to start. I would not be surprized if you eventually end up slightly under 9000 with that plane. What timer will you be using?
William
AMA 98010
Offline Bob Hudak
« Reply #4 on: May 01, 2012, 07:54:13 PM »
The Smoothie might like a smaller diameter prop for ground clearance. An 11x5.5 APCEP prop will do the job and you'll need to run it somewhere in the range of 9800 to 10050 rpm. It will use less mah from the battery swinging the smaller diameter blade too! What does the airplane weigh with the battery on board?
                                                   Bob
350838
Offline bob branch
« Reply #5 on: May 01, 2012, 07:58:03 PM »
A smoothie with that prop on 63 ft lines will turn a 5.25 sec lap at 8400 rpm.
bob branch
