  • June 16, 2025, 08:47:45 PM
Author Topic: Help Please!  (Read 2848 times)
Offline Peter Holmes
Help Please!
« on: March 05, 2010, 03:46:17 PM »
Spent the last few days reading 'Gettin all AMP'ed up' nearly @ the point of overload but feel ready to plunge feet first into the world over ECL. Not sure if I have a clue what I'm doing, but I'm probably in the right place to find out.
I have a profile Cardinal just dying to be electrified.
1. Managed to find a shop here in the UK with an ICE 50 lite in stock - purchased.
2. Is this battery worth buying? ebay item number 230442123260 - I like the safety aspect plus the idea of a 1000 cycles +
3. I selected this motor for the Cardinal: Turnigy AerodriveXp 32 SK Series 35-48 900Kv / 770W
4. With all the reading I've done, I reckon I need a Will Hubin timer - which one & why?
5. Battery charger, which one & why? - would like to be able to charge from the car @ the field, is this possible?
6. APC E 12x6 pusher
7. Have I missed anything?
Peter
Offline Mike Anderson
Re: Help Please!
« Reply #1 on: March 05, 2010, 07:39:15 PM »
Peter
OK - I'll start this off, then let others shoot holes in my answers  :)
       Good start - did you also get the Castle Link programming dongle?  You will need it.
       As one of the few on here who have actually used LiFe cells, I really wouldn't recommend them for a beginning setup.  They are too heavy for their energy capacity and are different enough from LiPo's that the "Knowledge Base" here won't be much help.  If you DO decide to go with them, I would recommend that you set up a 3s2p pack and use the 3548-1100 (rather than the 900).  Their advantages have been pretty much overshadowed by the latest LiPo technology and their price has risen, while LiPo's have fallen.
    That motor, with a 4s LiPo pack will do very well on a Cardinal - with the 900 Kv, you will probably need 2500-3000 mah capacity.
     Go straight to the horses mouth - whubin@kent.edu.  Tell him you've got an ICE 50 and he'll tell you which is the current model of timer you need.
      Depends somewhat on the battery you decide - most of the modern ones will handle A123's and LiPo's, but check to be sure that it is compatible with your battery choice - if going to HobbyKing for the motor, any of the Turnigy chargers will be adequate.  Be aware that many LiPo's are not recommended to be charged at a rate that is faster than the "one-hour" rate, so field charging can inhibit your flying time.  Also, pay attention to the maximum WATTAGE that a charger is capable of - even though some say "5 amps" max, they will only put in five amps if the voltage is less than 10 volts (5 amps multiplied by 10 volts is 50 watts).  I've had the FMA Cellpro and the now have 3 Turnigy (or clones) 50-watt ones.  There wasn't much to choose between them.
    Seems to be the universal starting point -
    Nope - it really is pretty much plug and play at this point.  Be prepared to be amazed at the amount of 'hassle' you've been puttting up with .... until now.
 y1
Mike@   AMA 10086
Central Iowa
Offline Warren Leadbeatter
  • AUS-14782
    • My Home Page
Re: Help Please!
« Reply #2 on: March 05, 2010, 09:32:51 PM »
For the Castle ICE LITE you will need a Hubin FM-2 timer setup for Control Line Governor mode.  This timer will give a constant throttle output though-out the whole flight as the esc governor will keep the motor revs constant.
The other type of Hubin timer eg FM-0c is for the cheaper non governing esc's and so it ramps the throttle up as the battery voltage drops.   Depending on the setup the model may still increase or decrease speed over the time of the flight. ie. not as good as the Castle ICE
I am using the Turnigy 35-48 in a Pathfinder and I'm using Turnigy 3300mAH 4S 20C battery.  I'm using around 2800mAH on a 6 min flight with a 12x6 APC Pusher running at 8600 rpm.  You should choose a battery a little bit bigger than required so that you only use 80% of the mAH on a flight.  This is the rule everyone seems to follow and it will prolong the battery life.
The charger I use is the Turnigy Accucell-6  This is a good charger, that can charge Lipo Life, nicad, Nimh, and Ledacid cells. It runs off 12V and has a car battery save feature so it wont flatten your car battery in the field.
Check it out at: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=7028&aff=210543
They also have a 8 cell version which cost more but allows you to charge 2 4S packs at the same time using a double adapter cable.  I also like the look of the GT A6 and A8 chargers.
Warren Leadbeatter
Port Stephens, Australia
AUS-14782
  • AUS-14782
    • My Home Page
Re: Help Please!
« Reply #3 on: March 05, 2010, 09:43:46 PM »
The Castle ICE LITE 50 (and possibly others) comes with a voucher for a FREE Castle Link. valid until 1 Aug 2010. All you have to do is go online and order it and use the code on the voucher to get yours for FREE.
Warren Leadbeatter
AUS-14782
Offline Archie Adamisin
Re: Help Please!
« Reply #4 on: March 06, 2010, 08:09:15 AM »
Peter,
There are several ways to skin a cat.  The A123's have been improving.  The pack you had a link to was very interesting.  Nicely built and good capacity and power.  I am a little dissapointed in the weight though as you can get better bang for the buck with Lipoly's for that weight.  The 35-48-900 is a great 4S (14.8v) motor, so 6S1P A123's and the 12 x 6 wouldn't be a good match.  If you do decide to go with the 6S1P A123, I would suggest a Turnigy SK 42-40-750Kv as it a an ounce lighter and has a better matched Kv for the higher voltage.  As far as chargers, I use the Turnigy Accucel 8.  It is the best charger I have seen for the money.  It will charge and balance the A123's.
Good luck with your selection.  You are on the right track and will be very successful!!
Archie Adamisin
Muncie, Indiana
Archie Adamisin
Burlington, KY
Re: Help Please!
« Reply #5 on: March 06, 2010, 08:27:34 AM »
OK - so I'm heading in the right direction.
Mike, I'll drop the idea of A123's for the time being- would these be ok or is 15C a problem? 260359118950 (ebay item number)
Note taken Warren,
HobbyKing
Turnigy 3300mAh 4S 20C Lipo Pack = $35.00
Turnigy 3000mAh 4S 20C Lipo Pack = $21.95
I want to order 3 - In all honesty would I be pushing my luck by opting for the 3000mAh, it would be nice to save nearly $40
Turnigy Accucel-6 50W 5A Balancer/Charger w/ accessories = $24.99
12V 5A Power Supply                                                     = $9.99
Turnigy Watt Meter and power Analyzer                            = $23.95
Car Cigarette Lighter Adapter for charger                          = $1.99
The ICE 50 lite turned up this morning, Castle link (dongle) ordered.
Waiting to hear from Will on a timer
Re: Help Please!
« Reply #6 on: March 06, 2010, 08:54:45 AM »
Thanks Archie for the heads up ;)
I'm going to drop the idea of A123's for the moment. As with most folk here, things need to be done on a budget so any big mistakes I can avoid while going through the growing pains of setting up, is most welcome. If I can avoid spending money where I don't need to then all the better ;D
For the time being, I can't see myself giving up on IC engines - just snapped up a O.S .46 VF - $65, that has to be the bargain of the century (anyone in desperate need of an R/C carb) - I can see a piped Bob Hunt 'Saturn' taking shape on the building board in my minds eye :)
But have to admit the are many things with ECL that appeal to me, no doubt others who are flying ECL could list multiple reasons why not to go back to IC. With noise being a major complaint these days, it's becoming hard just to pop down my local field to even fly a Peacemaker on a sunny summers day. What ever happened to 'live & let live'  R%%%%
But I do feel that this season could be full of Ohms & Watts ;D
Re: Help Please!
« Reply #7 on: March 07, 2010, 12:09:49 AM »
HobbyKing
OK, I really recommend that you NOT buy those cheap batteries from Ebay - I accidentally won an auction from one of those Hong Kong drop shippers - a 4 cell, 4000 mah, 20 C battery for a total of $27 including shipping.  This thing was a no-name, but from a supplier that had thousands of feedbacks and a large Ebay store.  It was a joke - at 5 amps, it puffed up and got extremely hot and I couldn't think of any use for it, so I ran it dead, cut the connectors off it, drove a nail through it and threw it away.  Basically, I got a 4 cell balancing plug and a Dean's clone (which I don't use) for $27.
The Turnigys are generally pretty good and getting better - I just bought 3 of the 4-cell 3000's (20C) and haven't done anything with them yet, but also got 3 3-cell 3600's and have done a full "break-in" as outlined by Kim D. - then did some test running and am quite pleased with them.  My 3-cell setup uses about 3000 mah to fly through the pattern (12-6 @ 8200 RPM) so a 3600 is about right.
Your capacity needs will be an inverse function of your Kv to some extent, so an 1100 Kv will need more capacity than a 900 Kv to turn the same prop at the same RPM.  I am figuring that a 4-cell driving a 900 Kv will need about 2400-2600 mah, so the 3000's should be OK.  If it pulls a little too much current, I will back off the prop to an 11-6 or 11-7 - I've flown both and they are very nearly the equal of the 12-6.  For certain, the extra 300 mah isn't worth an extra $15/pack.
Mike@   AMA 10086
Central Iowa
  • AUS-14782
    • My Home Page
Re: Help Please!
« Reply #8 on: March 07, 2010, 01:03:29 AM »
Those Turnigy 3AH 4S 20C's are exceptional value at that price!  I'm tempted to buy 3 myself!
Warren Leadbeatter
AUS-14782
Re: Help Please!
« Reply #9 on: March 07, 2010, 08:50:40 AM »
Peter
First off WELCOME to Stunt Hanger and the ECL forum.  010!
You choices all look very good for your Cardinal.. I think you will be OK with the 4Sx3000 packs IF:
* You fly on .015 x 63' (or shorter) lines.  NOTE this is about what you should be using on the Cardinal anyway.
* With the 12x6P you should need around 8600 - 8800 RPM.  This should deliver lap times somewhere in the 5.0 to 5.4 sec range.
Last summer I was flying a testbed Pathfinder (about 40 aquare inches larger than the Cardinal) with a larger motor  and a 4Sx3600 pack which proved oversized.  TH bird weighed in at 61 oz and I flew it on 018 x 66' lines and used 2550 - 2650 mah.  I actually flew it successfully with a 4S x 2800 pack but that was too close to the limits.
With that set of tests concluded I converted the airplane to a right-sized power system and will also plan to use 015 x 63' lines - which will be fine for this airplane.  I installed an Arrowind 2820 motor (slightly smaller than your choice) and expect to safely use a 4Sx2800.  The combination of the smaller motor and pack reduces the weight to 54 oz. I will also be changing from .018 x 66' to .015 x 63' lines which will substantially reduce the power usage.  The combination of lighter airframe weight and shorter/lighter lines will easily enable the usage of the 2800 pack.
Your Cardinal should finish in the low 50 oz range (give or take) and should be about as clean (or slightly cleaner?) than the Pathfinder.  The 4Sx3000 packs should be safe for your application.
A small warning.  Once you start flying ECL its HARD to go back to flying IC!   #^  AP^
Re: Help Please!
« Reply #10 on: March 07, 2010, 09:50:52 AM »
Thank you Dennis for your warm welcome - in between reading Mike & Warren's last post I went ahead and ordered 3 X 3000 4S lipo's, plus the other bits & pieces previously mentioned - bar one alteration, I decided to go for the Turnigy Accucel-8 150W 7A Balancer/Charger which should allow me to charge two batteries @ a time.
Have exchanged several emails with Will and he's mailing me a timer (FM 2a) + lead with remote push button for future use on full fuselage models.
Warren it was your set-up with the profile Pathfinder I'd used as reference - did a little mental gymnastics and reckoned I could use a slightly smaller battery - 3000 4S as opposed to 3300 4S you have. With them being $15 a hit cheaper, $45 was not to be sniffed at.
As I previously mentioned I've managed to read most if not all of the 13 pages of 'Gettin Amp'ed' - lots to digest, but it's all there.
Motor mounts for profile models are what I'm working on @ the mo, being an ex toolmaker & owning a milling machine & lathe I'm hoping to come up with something machined from a block which supports the motor front & back. I'm envisaging some sort of drop in cradle.
Did I mention Dennis, snapped up a O.S 46 VF cheap, real cheap - So I'm hoping that ECL doesn't prove to be too addictive as I'm goning have to sell a load of IC engines  :( I'm not sure I can do that, childhood memories & all that sentimental crap some of us have for model engines.
Offline bob branch
Re: Help Please!
« Reply #11 on: March 07, 2010, 05:57:39 PM »
Peter
Guess I'd better get off my A** and get my two PA .51's and their headers and pipes listed. You don't know it yet but you are about to flood the IC market. Beter get mine out there before you do.  y1
Welcome to the joy!
bob branch
Re: Help Please!
« Reply #12 on: March 09, 2010, 09:11:14 AM »
Peter
Welcome to the joy!
bob branch
Thanks Bob - but really I can't bare to part with them.
Another question for those flying ELC.
Which connectors are the preferred type? (Battery to ESC to Motor)
Powerpoles
Ultra Deans
Bullets & which size, 2, 3 or 4mm
And have I read correctly that ideally I need to keep the total length of wiring between the three below 9"
Offline Ron Dodd
Re: Help Please!
« Reply #13 on: March 11, 2010, 02:15:17 AM »
not a particularly good idea to charge from your car battery as it will destroy it quickly...starter batteries are not made to be drawn down as far as it takes to charge a bunch of 3000 mah cells..they are made to give lots of amps for a very short period of time then be recharged presumeably by the alternator on the motor it just started....they are not made to have 5 or 10 amps drawn out of them for an hour or two at a time.....get yourself a deep cycle battery and you will be much happier.........And NEVER charge from the cigarette lighter socket.....it ain't made to do what you will be asking from it......oh and a good place to get deep cycle Gel cell batteries is a shop that sells electric handicap scooters...I get them used for some of the guys here, and they run about 10 to 20 dollars ...when they change one bad battery in a scooter, it's pretty much mandatory to change the two good ones too..otherwise the old batteries will damage the life span of the new one...so there's usually 2 good batteries that need to be disposed of, and around here they gotta pay for that, so they are happy to get a twenty for it.
Offline bob branch
Re: Help Please!
« Reply #14 on: March 11, 2010, 05:58:35 AM »
Just a note that if you charge all your packs at home before you go flying and have 3 or 4 packs you can charge off the car without any problem. That is what all of us locally have been doing electric for a long time with the pack sizes we are using in stunt. I talked with a top rc 2 meter pattern flier who flies electric on 10S setup and he carries a tiny honda generator to recharge his packs. But he also carried so many packs (he is sponsored) that I cannot believe its an issue. He is flying multiple 5K mah packs though.
I am not disputing that if you charge from scratch all your packs at a field it would be tough on your car battery. Also agree a deep storage battery would be better. I use one at home as well but I'm not going to carry that much weight and put it in the car each session. Anyway, your milage may vary. I am just relating what a number of us are experiencing locally in charging electrics at the field.
bob branch
Offline Dean Pappas
Re: Help Please!
« Reply #15 on: March 11, 2010, 10:54:18 AM »
Hi All,
My experience is that a 10S/5A-H pack is good for one recharge on a car battery, and the second is dodgy unless you run the car for maybe 15 or 20 minutes to partially recharge beforehand.
For a 4s/4-A-H pack, I'd say 3 or 4 charges between running the car is fine, and my minivan does not have a particularly large capacity battery.
Do avoid the cigarette lighter for a variety of reasons, the most of which is to get the batteries being charged away from the vehicle!
I use a set of standard jumper cables directly from the battery, and I clip them charger end to a large wooden dowel, to gaurantee that the two giant clips cannot ever short together.
The charger(s)  clip to them.
take care,
Dean Pappas
Dean Pappas
Offline Ron Dodd
Re: Help Please!
« Reply #16 on: March 11, 2010, 11:24:24 AM »
Since we're on the subject, I have my "charge station" permanently wired into the back of the pickup..it is isolated so that I cannot drain the starter batteries by using it..the Hyperion chargers will not start unless the switch is used to disconnect the main vehicle battery.....then it will charge up when I start the truck and drive home....I also use 24 volts, since my chargers are made to use up to 27volts, and I find them much more efficient on 24 volts..especially when I'm charging 10 or 12... 5000 mah cells..also cuts charge time down... On this setup, I can charge all day at an F3A event, and likely could make the second day..assuming I start from home with charged batteries....
 I stumbled onto this site because I was thinking to do up a control line model for electric, and was searching for information on models, since I haven't flown CL for about 50 years, I figured I better do some catchin up  ::)
this overall is a really good forum..congratulations guys well done
Offline Dean Pappas
Re: Help Please!
« Reply #17 on: March 12, 2010, 06:17:30 AM »
So how many pounds of battery do you have in the back of that truck, Ron?
take care,
  Dean
Dean Pappas
Offline Ron Dodd
Re: Help Please!
« Reply #18 on: March 12, 2010, 10:00:19 AM »
Dean:
 likely about 150 or 160 pounds..haven't weighed them exactly, but I will tell you, too much for an old F-rt like me to be packing back and forth from the house.  :P  And since I spend some serious time at the field ...like three evenings a week, and events every weekend through the season, I needed something easy and reliable...those deep cycle gel cells just keep chuggin along....three seasons and coming up on the 4th.
Offline Dean Pappas
Re: Help Please!
« Reply #19 on: March 12, 2010, 03:40:16 PM »
Hi Ron
Not everyone can manage a semi-fixed battery installation like that in their vehicle!
What the market needs is a voltage spike suppressor/filter for folks to be able to use their chargers while the car runs. many of them get cranky if the car is running.
later,
Dean
Dean Pappas
Re: Help Please!
« Reply #20 on: March 12, 2010, 09:27:11 PM »
I take it that the switch that switches the gel cells between the truck circuit and the airplane-battery charging circuit also switches between 12V parallel and 24V series gel cell operation.  Pretty clever.
Offline Ron Dodd
Re: Help Please!
« Reply #21 on: March 13, 2010, 01:42:11 AM »
actually it wasn't really all that difficult to do..the starting system for the pickup is 2 twelve volt batteries, they charge as 12 volts, run all the lights....radio...heater etc....on 12 volts, but are hooked to the starter in series for 24 volts...so I kinda copied that setup. works really well, and has had more than a few fellows looking at it and scratching their heads......I have two sets of polarized plugs...standard deans for 12 volts, that anyone can hook into, and screw in polarized plugs from a Boeing 727 for 24 volts for my chargers...decided to do that so that anyone who needed to plug in their charger wouldn't accidently get 24 volts..also have 115 volts AC back there from the panel for a soldering iron..standard household plug in.....there are also other mods to the box, such as a slide out work/assembly bench and model stand for putting together my larger ( 1/4 and 1/3 scale) models...and wing racks. believe it or not, I can get a 1/3 scale DR1, a 1/4 scale sopwith Pup, a 1/4 scale Tiger moth..and a couple park flyers in the back of a short box Dodge pickup along with a flight box and 4 drawer tool box...AND still close the tail gate and canopy door   :o
Ok almost ready to rumble
« Reply #22 on: April 24, 2010, 01:04:47 PM »
Electrified the Cardinal and she's ready to fly:
Just need a little help to set the ESC (Ice Lite 50) & Hubin FM-2a, I want to start with the shortest possible flight time for trimming and not to scare myself sh**less. Planning to use 62' lines - 12x6 Turnigy Light electric prop (wood tractor)
Peter
Re: Help Please!
« Reply #23 on: April 24, 2010, 01:10:45 PM »
Just a few more photos
Peter
Offline Robert-Jan
Re: Help Please!
« Reply #24 on: April 24, 2010, 01:11:16 PM »
Peter where do you put your battery,
I put mine in front of the wing.
We were typing at the same time.
I see the awnser in the pictures
Greetings Robert-Jan
Re: Help Please!
« Reply #25 on: April 24, 2010, 01:16:34 PM »
Last three - Promise !!!
Hope to fly tomorrow - Plenty of sunshine & low winds forecast for the S.E of England.  ;D
Forgot to add - Have a 12X6 APCe pusher in reserve
