Electric Stunt => Gettin all AMP'ed up! => Topic started by: Kevin Muckleroy on July 28, 2018, 09:23:26 AM
Help-EP All American Sr?
Anyone got pictures of how/where the ESC and Timer are installed on a Brodak All American Sr with Brodak E-Conversion?
Hi Kevin
You are right the nose is TIGHT! After struggling with other options I finally just cut a hole in the bottom of the fuse and mounted the ESC flush with the bottom. At the very least it gets GREAT cooling this way!
The FM-Hornet timer just kind of nestles ahead of the battery & behind the motor mount plate. THe starting switch and fine adjust pot are on the fuse just behind the motor mount plate.
Thanks , Appreciate the help.
