  • July 28, 2025, 07:08:09 PM
Author Topic: Help! Anyone with a SkyPower ESC and a servo tester out there?  (Read 1613 times)
I've got three people now who have TUTs installed in airplanes for engine sequencing.  They're our own Fred Cronenwett, and two RC guys who read his scale column.
Fred and one of the new guys are having no problems, and just love the system.  The other guy is having no end of trouble.
I think it might be related to the ESC he's using -- by default, I have the idle threshold on the TUT set fairly low, and I think that his motors are getting told to start at idle, but aren't.
He's using SkyPower 20amp ESCs with 4amp switching BEC.  If there's anyone out there that has one or more of those, and has a way of knowing what pulse width is getting sent to it (either because you have a servo testing box, or because you've got an RC transmitter that'll let you know pulse widths), could you check and see at what throttle setting the thing starts the motor turning?
It would be a great help to me, my new customer, and possibly lots of customers down the road.
For that matter, if you don't have a Skypower ESC, but you have the other stuff and want to help out with this, measure the "starts to turn" pulse width and post it here -- then I can build up a table of brands and settings so that people know out of the box how to set things up.
Thanks in advance...
Offline Keith Renecle
Re: Help! Anyone with a SkyPower ESC and a servo tester out there?
« Reply #1 on: March 15, 2015, 12:05:11 AM »
Hi Tim,
I would guess that the SkyPower esc is like the vast majority of Chinese esc's out there, and like to have the throttle range calibrated up front by means of the usual "plug in the battery with the Tx on and the throttle stick at full throttle, and wait for the beeps, then pull the stick down to low throttle" system. Without doing this, the motor will not start up. It "should" be 1.0 ms for low throttle and 2.0 for full throttle but it is not always like that. On my system I allow for this by means of the switch in the ON position giving 2.0 ms and the Off position giving 1.0. The esc's are designed so that they will not start up if you switch on with full throttle pulse width. So to calibrate the esc's on my system, all you do is to put the switch into the ON position and plug in the battery, wait for the two short beeps and switch the slide switch OFF again. The esc then makes the motor play the usual start-up beeps and all is well. This calibration is also necessary to make sure that the user gets the maximum rpm as well.
I still get new customers that contact me with this very same problem and I refer them to the section in my instruction manual that explains this. I hope that helps.
Keith R
Keith R
« Reply #2 on: March 15, 2015, 12:42:33 AM »
Hey Keith:
That could certainly be the problem.  I've sent an email to the customer, I'll see what he says back.
