Electric Stunt => Gettin all AMP'ed up! => Topic started by: Jim Howell on August 12, 2012, 04:27:30 PM
Anybody know the differences between the Hacker A30-14L and the V2 version of it? I was trying to find out the kV rating of the A30-14L and all I seem to be able to locate on the web are specs for the V2 version. On the surface, I might jump to the conclusion that Hacker added the integral cooling fan to create the V2, but I've been known to get into a lot of trouble when I "jump to the conclusion" rather than ask for help.
Jim Howell
Jim
This is related to both of your questions.
Kv and pole count is used in the data logger to give you more accurate reading. Also in the governor mode to calculate settings. But I don't believe the ESC is dependent on the Kv for actual motor performance.
BTW A30-14L specs: Kv (rpm/V) is still 800
Norm
Jim
Norm
Norm,
Thanks for the response and the tech info. I think I can understand why kV and pole count would affect the data logger. I hadn't thought about that aspect. I had assumed that the settings being calculated were part of Castle Link's "user help" to assist me in getting the operation set-up in the right ball park for matching the motor, battery, and desired performance. I would be interested in knowing more about how the governor mode actually works. Again, I had assumed that, using that option essentially bypassed an expectation that the RPM would be determined by an external signal from an R/C receiver and allowed the ESC to function purely on internal programming.
Thank you.
Jim
It so happens I just purchased a Hacker A30-14l, here is the spec I pulled down from the internet. I have it in a 33 ounce plane and it seems to be working fine, but I am still in the trim phase. Hope this helps.
Andy
Aero-Model Inc./Hacker Brushless A30-14L Brushless Outrunner Motor V2
Features
800kv (rpm/volt)
500watt continuous 600watt peak
Operating current 40amps peak current 50amps
14 pole & curved magnets
Bolt-on & Collet style prop. adapters, Aluminum X-Mount & Hardware package
Incorporated Cooling Fan
Specifications
Weight: 5.6oz.
Diameter: 1.46"
Length: 1.81"
Shaft dia.: 5mm
Prop adapter dia.: 6mm
