Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 11, 2025, 04:49:20 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Electric Stunt
Gettin all AMP'ed up!
(Moderator:
Dean Pappas
Gyroscopic Progression
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Gyroscopic Progression (Read 1180 times)
Will Moore
Trade Count:
0
Commander
on:
September 16, 2013, 06:04:21 PM »
What is the current thinking among the engineers out here regarding
Gyroscopic effects on the airplane from the light electric APC and
Carbon fiber copy cat props we use.
1. Does rpm have an effect, is lower better that higher (?) or
2. Is the diameter the more important consideration?
What are the advantages and disadvantages.
Logged
Things take longer to happen than you think they will,
Then they happen much faster than you thought they could.
AMA # 209
Phil Krankowski
Trade Count:
0
Admiral
Re: Gyroscopic Progression
Reply #1 on:
September 17, 2013, 06:30:57 AM »
http://en.wikipedia.org/wiki/Precession
RPM increase will increase the forces.
Diameter increase will increase the rotational inertia, and at a given RPM increase the force.
A diameter increase with a reduction of RPM may or may not increase or decrease the forces involved.
I have not considered how it affects control line flying.
Phil
Logged
Dan Bregar
24 supporter
Trade Count:
0
Captain
Field Marshall
Reply #2 on:
September 17, 2013, 09:13:20 AM »
In regard to advantages vs disadvantages, I have seen larger dia. can hurt your corners, mostly the squares. Ever notice how some top notch flyers run 3 blade props ? Sometimes the reason is not just for ground clearance.
Logged
AMA 33676
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Electric Stunt
(Moderator:
Dean Pappas
