  • July 29, 2025, 08:34:38 AM
Author Topic: Great 12V 20 Amp Power Supply  (Read 1132 times)
Offline Rudy Taube
  • Ret Flyboy
« on: February 13, 2008, 02:11:10 AM »
Hi Gang,
If you need a quality, 12V, 20 Amp power supply (or a second one ;-) you may want to try my friends at sin city jets. This is a good company, with very good customer service and low prices. .... I would say that even if they were not my flying buddies in LV.  ;-)
 http://www.sincityjets.com/store-batteries.htm
They have an excellent 12V, 20 Amp power supply for around $75. It is way cool, with two cooling fans and blue lights inside showing through the lightning holes in the metal case. This is a very light unit that is also small in size. It comes with THREE sets of female banana plugs mounted to the case so you can plug in THREE chargers at once! Perfect for our ECL use. It is in the "Accessories" section.  .... And, if you have some extra $$$$$ laying around, they also have some great deals on jet turbine setups.  n~
PS: I am a big fan of buying extra chargers, (I use three). They are cheaper than extra batteries, speed up the charging process, and are very convenient!  y1
Rudy
AMA 1667
