Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 21, 2025, 05:26:13 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Electric Stunt
Gettin all AMP'ed up!
(Moderator:
Dean Pappas
Battery break-in
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Battery break-in (Read 3724 times)
Larry Renger
21 supporter
Trade Count:
0
Admiral
Battery break-in
on:
September 29, 2016, 08:00:41 AM »
I ran a search and found a couple of references to battery break-in, but no specifics. Why is it needed and how is it done?
Logged
BTW, Dracula Sucks! A closed mouth gathers no feet!
Motorman
Trade Count:
0
Admiral
Re: Battery break-in
Reply #1 on:
September 29, 2016, 11:02:55 AM »
Did you read this
http://stunthanger.com/smf/gettin-all-amp'ed-up!/discharge-rate-while-flying/
Hmm... how come the full link never comes up? Anyway it's not hard to find.
Just set your charger for the lowest termination voltage usually 4v then set your timer for 3 minutes and put on a much lighter load prop and set the rpm very low about 5-7k then charge and run the battery on the ground about 3-4 times and that should do it. You can also just fly the battery normally without break in but it'll get hot the first few times and won't last as long.
Logged
Larry Renger
21 supporter
Trade Count:
0
Admiral
Reply #2 on:
September 30, 2016, 06:01:27 AM »
Got it, thanks! I don't know why that didn't come up on my search, but it fills the bill!
Logged
Fred Underwood
Trade Count:
0
Captain
Reply #3 on:
September 30, 2016, 04:23:45 PM »
I did the search once and found only this thread. I changed word order in the search and tried again and found more. There is some variability in the search function. Some threads here with a variety of methods
http://stunthanger.com/smf/gettin-all-amp'ed-up!/battery-discharger/msg460875/?topicseen#msg460875
http://stunthanger.com/smf/gettin-all-amp'ed-up!/lipo-batteries-safety-and-handling/msg29269/?topicseen#msg29269
http://stunthanger.com/smf/gettin-all-amp'ed-up!/battery-break-in/msg92424/?topicseen#msg92424
Logged
Fred
352575
Motorman
Trade Count:
0
Admiral
Reply #4 on:
September 30, 2016, 05:15:58 PM »
Once again only half the link, Robert what's up with that?
Logged
Joe Yau
AMA Member
Trade Count:
0
Captain
Reply #5 on:
September 30, 2016, 07:44:48 PM »
Quote from: Motorman on September 30, 2016, 05:15:58 PM
You have to use the Hyperlink for the URL..
No hyperlink:
With Hyperlink:
Logged
Joe Yau
MAAC: C-9996
https://www.facebook.com/profile.php?id=100005109198732
Motorman
Trade Count:
0
Admiral
Reply #6 on:
October 02, 2016, 04:19:45 PM »
Logged
Russell
ACE
Trade Count:
0
Lieutenant
Reply #7 on:
November 07, 2016, 02:03:04 AM »
Put your URL aka link between these: <>
Example: <link>
Logged
john e. holliday
25 supporter
Trade Count:
0
Admiral
Reply #8 on:
November 08, 2016, 07:54:00 PM »
I'm lost.
Logged
Shawnee, KANSAS 66203
AMA 23530 Have fun as I have and I am still breaking a record.
Russell
ACE
Trade Count:
0
Lieutenant
Reply #9 on:
November 09, 2016, 02:17:55 AM »
Quote from: john e. holliday on November 08, 2016, 07:54:00 PM
I'm lost.
The problem with the link is the handling of special characters. Using "Insert Link" behind the scenes is enclosing the link with
test link
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Electric Stunt
(Moderator:
Dean Pappas
Battery break-in
