  • June 17, 2025, 11:51:53 AM
Author Topic: ESC resistance  (Read 1450 times)
Offline Larry Renger
ESC resistance
« on: January 12, 2015, 12:14:33 PM »
Do ESCs have lower resistance as the Amperage rating goes up?
Re: ESC resistance
« Reply #1 on: January 12, 2015, 12:18:17 PM »
In general they will, yes.  But it'll vary by manufacturer and model.  Older ones will probably have higher resistance than newer ones -- the progress in MOSFET technology in the past ten years has been absolutely astounding.  If you're a circuit designer, you can pretty much select a transistor for your circuit confident in the knowledge that by the time you get a prototype board back for testing, your spiffy new transistor's performance has been superseded by something smaller and with markedly better specifications.
