  • June 17, 2025, 05:26:03 AM
Author Topic: 1/2 A electric equivalent  (Read 2032 times)
Offline Glenn Quarles
« on: December 31, 2014, 06:39:20 PM »
Friends, I asked a similar question in the scale section and didn't come up with an answer. Is there a formal published electric setup that can be used in the 1/2A events? Something about the Renkar rule?
Thanks!!
Glenn
Live in such a way that those who know you, but don't know God will come to know God because they know you.
Offline Larry Renger
Re: 1/2 A electric equivalent
« Reply #1 on: December 31, 2014, 07:16:24 PM »
We limit the use to a total of 16 Ahr battery capacity. Use it as you wish. Generally, that is used as a 1325 mAh 3s battery. But you could use a higher capacity 2 s or lower 4s. I have a Baby Flite Streak that flies just fine on a 3s 850 mAh pack.
My Baby Pathfinder needs the full capacity of 16 mAH.
« Reply #2 on: December 31, 2014, 09:52:13 PM »
Very good, thanks Larry! Does this only apply to 1/2A stunt? I got the impression from the scale forum that only IC is allowed in 1/2A.
Thanks again!
Glenn
« Reply #3 on: January 01, 2015, 07:52:49 AM »
This is for our local 1cc aerobatics event. So far as I know, there are no national rules.
« Reply #4 on: January 01, 2015, 09:43:07 AM »
Thanks Larry, that is the exact info I was looking for!
Glenn
