  • August 04, 2025, 11:16:14 PM
Author Topic: Igor’s instructions on flight timer/Jeti 66 programming (my 1st electric)  (Read 1456 times)
Offline Ron Vargo
Hey guys I bought all this new stuff from Igor for my 1st electric . Every where I’m trying to find info on Programming on Igor’s pages and other places on stunthangar they don’t seem to be working . I need to set up the jettispin 66 with the Jetti box and program the flight controller. I have never set one up.    Any info would be great.  Thx guys
Here's some stuff:http://maxbee.net/downloads/downloads.htm
Here are my settings.  These are for a 10-pole motor and 6S battery. If this makes the prop turn backwards, set Rotation to Right.  Target throttle is whatever you need to get the speed right.  Increasing it makes the airplane go faster.  I'd start with sensitivity = 0, then use a nonzero setting when the airplane gets pretty close to being in trim.
Offline Peter Coates
If you bought your stuff new from Igor then it is already programmed by him.
After a few flights you may wish to make adjustments to suit your own preference.
Otherwise go with his settings and they will get you flying safely
Offline Ron Vargo
Thx guys........ I appreciate your reply
