  • June 16, 2025, 09:35:39 AM
Author Topic: How many "C" do I need ???  (Read 807 times)
Offline jim gilmore
« on: September 16, 2010, 10:03:29 AM »
If I decide to buy my own set-up using the info I've read how many "C" matteries should I look for.
I see batteries rated 15 c or do I need to look at higher "C" Rated batteries to be safe ?
If I need 1000-1200 capacity in a 3cell pack so I can get a little higher. That will puch the amperage up but how many amps in then enough in an esc ? Should I get a 25 instead of a 10-15 esc ?
lots of variations here ?
Re: How many "C" do I need ???
« Reply #1 on: September 16, 2010, 10:21:41 AM »
First: there's a lot of marketing fluff involved in the 'C' rating of a battery.  So read the label carefully, and if it bursts into flame any way just don't buy that brand any more.
Second: You're probably OK with today's batteries, unless you want really short flights on light batteries.
The 'C' rating of a battery is an estimate of the amount of current it'll generate, as a proportion of its capacity.  So a 1000mAh, 1C battery, should be used where its not going to deliver more than 1 amp (1A = 1000mA).
You want flights that last about six minutes (I assume), which means that you want a 10C or better battery (in theory running the battery at 10C would bring it to 100% discharge in six minutes -- but remember that you're aiming for 75% discharge or less, so 10C gives you some overhead).  If you're desperate for weight savings and you don't mind using the batteries hard you may want to do something like plan on a three minute flight with 20C batteries.
I don't necessarily trust numbers over 15C, unless the battery manufacturer is one of the known-dependable 'big names'.  Because there's no standard for what the 'C' rating for a battery is, rating a 1000mAh battery as "30C" could mean anything from "pull 30A for it for one second and it won't burst into flame but all other warranties are void" to "pull 30A from it for 90 seconds every day for a year and then think about replacing it".  It really boils down to how responsible the manufacturer is about trying to sell batteries to not disappoint vs. selling them to make money quick.
So -- how long of flights are you planning on?
Offline jim gilmore
« Reply #2 on: September 16, 2010, 11:17:28 AM »
Well i have never done the full pattern in my life. So a three min flight to start might be a good starting point.
Seeing what I can get on a flyable haff A is the goal. Once I'm sure what I got I could keep playing and the decide what I need to do or which way to go.
Working goals are in this order.
1-Get required items and build test mount.
2-Run on ground and derermine best mount and configuration.
3-build flying model and fly. "determine if It needs more or less".
At the moment I'm looking if buying from hobbyking is viaable and cheaper than going through other sources.
One thing I have is time....I'm pretty much stuck watching my mom who may well outlive me even with her alzheimers.
« Reply #3 on: September 16, 2010, 11:25:40 AM »
I bought some batteries from Hobby King and so far they're OK -- but I've been using them in RC planes at less than 10C rates.
If you're really going to fly for just three minutes and you want to keep the batteries light I'd say look for batteries that are advertised at 20C or better, and if they say "continuous" that's even better yet.
To some extent the motor & battery you get depends on the airframe; make sure you have an idea of the all-up weight of the airframe is going to be before you get the electric stuff.
Good luck with your mom, and my sympathy -- having one of my elder relatives succumb to Alzheimer's is something that I dread.
Offline john vlna
« Reply #4 on: September 16, 2010, 12:39:56 PM »
I have had good luck with batteries from 15C and up. Just make sure you allow some margin on the battery, After determining my max Amps, duration of flight wanted, etc, I increase battery capacity by 25-30%. For example a TP 2408-21 is rated at 13a max, it will draw more, but if I plan to fly at 13A or less for 5 minutes, I would choose a battery that could supply at least 16 A continuosly.  A 1300mah  a 15C could give a continuous current of 19.5A, and a duration of (1.3ah/13a) x 60min/h  = 6 min
