  • June 29, 2025, 12:30:29 AM
Author Topic: JMP-2 TIMER Durability  (Read 990 times)
Offline Crist Rigotti
« on: August 06, 2008, 09:23:37 PM »
Guys,
My JMP-2 timer looks like it gave up the ghost.  I was bench testing it a learning to program it.  It was working great then it just seemed to quit.  I never plugged it in backwards either.  How has your timer worked for you?  I'm hoping it was just infant motality.  Anybody have theirs quit too?  Glad I ordered 2 more the other day!
« Last Edit: August 07, 2008, 06:34:28 AM by Crist Rigotti »
Offline Rudy Taube
  • Ret Flyboy
Re: JMP-2 TIMER Durability
« Reply #1 on: August 06, 2008, 10:32:03 PM »
Crist,
The short answer: THEY ARE VERY RELIABLE! :-)
I'm sorry to hear you had a problem, glad that it happened during "test" ;-)
I have over 250 flights on JMP timers. In the beginning I had three of them all with different programs, for the 1st 25 flights. This allowed me to make quick changes at the field. After the 1st 25 flights, I had the setup and prop where it was perfect for me. Since then I have used the same JMP timer for 225 flights with NO problems. Will Moore has hundreds of trouble free flights on his JMP timers, as do others.
I would suggest that you send it back to where you bought it. Jean-Marie is a nice guy, you may get an exchange?
Rudy
AMA 1667
Alan Hahn
« Reply #2 on: August 07, 2008, 12:08:20 PM »
Well except for the one time I plugged it in --one pin shifted-zapp!, it has been very durable.
However I did have one that didn't work the when it arrived. It turned out, after close inspection, that some of the pins weren't soldered. A quick touch up fixed it and it has worked just fine ever since. Might want to check the push button and the IC to make sure you see a good solder joint.
« Reply #3 on: August 07, 2008, 01:24:11 PM »
Good idea Alan!  I'll check it when I get home.
