  • June 22, 2025, 06:25:38 PM
Author Topic: E Flite spinners  (Read 1664 times)
Offline Arch Adamisin
E Flite spinners
« on: January 18, 2010, 09:58:05 AM »
Hi gang,
I've exchanged a couple emails with Pete @ horizon and asked if it might be possible to get some of their spinners in 1.75" and 2 " either without the prop notches so we could fit them to our reverse pitch props or even to 3 blade props. Is anyone out there interested in some if they will run a batch? The higher the response, the more likely the possibility that they might make us some. Please let me know ASAP, Pete is in China right now.
     Arch
Offline Mike Scholtes
Re: E Flite spinners
« Reply #1 on: January 18, 2010, 10:16:46 AM »
How about notched for the most common APC pushers, especially the 12-6EP? Also the 3-blade pushers from Master Airscrew? And while we are at it, how about E-spinners with openings/vents that would allow air to pass through the spinner to the front of the motor, if this is feasible? I recognize that the world market is probably small for CL-only items like this but we won't know unless Pete asks!
« Reply #2 on: January 18, 2010, 12:08:11 PM »
I'm in for a half dozen or so 2" ones with left hand prop cutouts
Offline Paul Walker
« Reply #3 on: January 18, 2010, 12:36:10 PM »
Yes, I could do with half a dozen pusher 2" spinners.  I use the regular e-flight spinners with the tractor props, and they are light.
Thanks for the effort.
Paul Walker
Offline Larry Wong
« Reply #4 on: January 18, 2010, 02:46:39 PM »
I could go for 6# 2"  also for pusher props, are they plastic or Aluminium?
Larry
« Reply #5 on: January 18, 2010, 04:23:09 PM »
Dennis,
I like the idea of the uncut so we could use it for 3 blds. Count me in for 2" size will do 6 of either. Any choice on color?
Best,     DennisT
« Reply #6 on: January 18, 2010, 06:58:01 PM »
Heres the link to the 1.75"
http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLSP175
Heres the link to the 2"
http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLSP200
What Arch is talking about is a small limited order of this with (more than likely ) NO prop cut-outs so they can be custom cut for LH 2-blade or LH or RH 3 blade (or more blade)
« Reply #7 on: January 18, 2010, 09:28:58 PM »
It would be of interest to me as well, probably a couple of each.
Offline Rudy Taube
  • Ret Flyboy
« Reply #8 on: January 18, 2010, 11:23:08 PM »
Thanks Arch,
These look like good elec. spinners, at a very good price.
I have been using the beautiful TruTrun Electric spinners, they seem to work very well and are works of art. They come in many sizes, colors,2 or 3 Blade, and they will custom cut them for any prop you want if needed. They cost more than the E-flites, but they are a great alternative if you want a beautiful, light, E spinner and don't want to try and cut your own slots.
Rudy
AMA 1667
« Reply #9 on: January 19, 2010, 12:33:48 PM »
I wrote to Pete, explained that there is a fair amount of interest and we'll see where it goes from here. As soon as I hear back from him, I'll let everyone know.
Thanks for the interest, Arch
Offline Paul Walker
« Reply #10 on: February 01, 2010, 01:00:25 PM »
I wasn't aware that they were aluminum.
How much will they weigh?
Offline TDM
« Reply #11 on: February 01, 2010, 02:31:31 PM »
I could help and make the cut out for you on my CNC machine if you like. It can be made for any number of blades as long as they fit in. You just send me the prop and the spinner and I will cu it for you to match the blade.
Traian
