Hi Mike,
It's no secret that I am a big fan of ARs (ARFs/ARCs). With that said your idea of building just the fuse from your kit is a good one. When I started my Vector E conversion I wanted to cut out the MM, make the front lighter, top hatch, etc. It looked to me like it would be messy and more trouble than it was worth. So building a new front end from scratch looked like it would be easier. I'm glad I did it, the work load may be a push but the results are a little more E friendly. It gave me a full top hatch + the original bottom hatch and it is a little lighter with better cooling.
I cut the fuse right in front of the canopy, see photos below. Then made some patterns off of the original and made a few mods to make the very front a little wider for more room and better cooling. I hate wasting time doing any building, but it was easier to do than I thought it would be and I think it was easier than doing all the mods with the original AR front end. It allowed me to use the rest of the fuse that was well built, perfectly aligned, had the canopy, and had the wing cutout that made the wing fitting assembly easy. I used the under wing parts, etc. from the original. At the fuse splice I used 1/8" ply and Epoxy-Lite, it is stronger than the original.
We can all hope that the designers of future ARs will follow Brad's excellent lead with his E friendly T-Rex. With a top hatch added it would have been perfect! (Maybe I should forward this note to John? ;-) Brad's firewall motor mounting method and plenty of room up front makes for an easy E conversion.
My guess is that as the world, and later followed by the conservative US, quickly converts to ECL we will see more ARs become E friendly. This will make it easier for everyone. I am sure it is obvious to the most casual observer that having ARs that are more E friendly will help accelerate the movement to ECL. This will likely make it easier for some retreads to add ECL to their ERC model flying too. It will be great when we have ARs with top hatches, E MM (like ERC planes have), wing cutouts for battery location, and/or take-apart two piece RC type wings that will give us the whole fuselage for our E stuff, battery platforms, etc. all built in. .... We can only hope.
PS: Are you going to make it to the GSC next month? I hope so, we would all like to see you there.
