  • August 04, 2025, 02:17:16 AM
Author Topic: Tom Morris' motor mounts?  (Read 1760 times)
Offline John Rist
« on: May 25, 2012, 11:50:35 AM »
It's my understanding Tom Morris is building profile electric motor mounts.  I thought I saw some pictures of them somewheres.  Does anyone remember where?
Also what is the best way to contact Tom.     ???
Offline Larry Wong
Re: Tom Morris' motor mounts?
« Reply #1 on: May 25, 2012, 02:23:48 PM »
TryStunt News    November/December 2011 page 37
Hope this what your looking for!    y1 y1 y1
Larry
« Reply #2 on: May 29, 2012, 06:17:20 PM »
John,
See Ty's post on the Profile Caviler that Tom Morris had at the GA meet. Good pictures of how its installed. The mount is for a front mount system. It is a 3/16" plywood circle that is milled out for motor cooling, drilled for motor bolts and screwed to the mount crutch. It can be used in full fuse or profile ships. The mount is very strong and does not require an external rear bearing for  solid motor support (once the nose is shaped and all is final fit I CA the whole ring to harden it). Its a very good product.
Best,          DennisT
Offline Lynn Weedman
  • x47weed (Lynn Weedman)
« Reply #3 on: May 30, 2012, 06:05:03 PM »
I got some of those mounts from Tom at the KOI. Very nice work strong and lite too !!!! y1
Lynn Weedman VP X47FLYERS
Lynn Weedman
Offline Allan Perret
  • Proverbs
« Reply #4 on: June 10, 2012, 07:06:30 AM »
If you want to go Hi-Tech get a G-10 laminate mount from Bob Hunt.  $12 if I remember right.
Cut using CNC water jet, same precision as laser cut balsa parts.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Andrew Borgogna
  • Andy
« Reply #5 on: June 10, 2012, 09:27:25 AM »
Allen
Do you have pictures of the Hunt mount?
Andy
Andrew B. Borgogna
  • Proverbs
« Reply #6 on: June 10, 2012, 10:34:14 AM »
Allen
Andy
No, but I'm sure Hunt does.
Update.
See page 50 of current Stunt News.
« Last Edit: June 12, 2012, 05:26:10 AM by Allan Perret »
Allan Perret
AMA 302406
Slidell, Louisiana
