  • August 05, 2025, 12:07:36 AM
Author Topic: Vector to electric Battery compartment  (Read 3004 times)
Offline Fred Quedenfeld jr
« on: January 03, 2022, 08:20:34 AM »
Looking for pictures or sketches on converting the first vector to electric
Looking for Battery sled drawing or picture
Looking for hatch hold down  for hatch on side of fuselage
looking for a battery hatch on the inside
Top or bottom hatch needs velcro straps or bolt in battery sled   not enough room for my fat fingers
Fred Quedenfeld   fredf2c@copper.net
« Last Edit: January 04, 2022, 03:30:02 PM by Fred Quedenfeld jr »
Offline Don Jenkins
Re: Vector to electric
« Reply #1 on: January 04, 2022, 06:42:53 AM »
Are you converting a completed plane from IC to electric, or building it from the beginning for electric?  When you said first Vector, did you mean the original 58 inch span version?  I built this model using the Tom Morris 3D printed front mount and it worked out quite well.  These mounts are now available through "okie air.com", I can send pics if this applies to what you are doing, just let me know.
Don
« Reply #2 on: January 04, 2022, 11:46:35 AM »
Don
Ditto's - great mount.
Offline Don Jenkins
Re: Vector to electric Battery compartment
« Reply #3 on: January 05, 2022, 06:20:38 AM »
This is the Vector with the 3D printed mount.  A small cowl allows access to the motor and the ESC/Timer slides in below the battery floor. The battery side hatch allows moving the battery to achieve center of gravity.  Whether you use a front or rear mount I think a battery floor with side hatch would work.
Don
« Reply #4 on: January 05, 2022, 07:19:36 AM »
Don
The best mod ever for the Vector!
Offline Mark wood
« Reply #5 on: January 10, 2022, 03:36:29 PM »
Well, I'm late to this party. Here's mine. Crafted a new front end after an accident.
Life is good AMA 1488
Offline Mark wood
« Reply #6 on: January 10, 2022, 03:48:29 PM »
Here's some in progress photos. I cut the parts with my laser and they are available.
Offline Mark wood
« Reply #7 on: January 10, 2022, 03:51:03 PM »
Couple more
Offline Dwayne Donnelly
« Reply #8 on: January 11, 2022, 08:36:39 AM »
Nice work Mark
Offline Mark wood
« Reply #9 on: January 11, 2022, 11:51:32 AM »
Offline Mike Scholtes
« Reply #10 on: January 11, 2022, 06:21:44 PM »
Mark, is that a 7KCAB rudder photobombing your pics?
Also, interesting design work on the Vector nose; I think that's the best I have seen yet. Wish it was available when I built my 2 Vectors. I know some flyers who may be interested, if you are saying you can cut the parts.
Offline Mark wood
« Reply #11 on: January 11, 2022, 10:00:21 PM »
No that one is a 7ECA. I have two 7KCAB's up in my Newton Hangar. They're basically the same airplane, difference is the powerplant. I haven't exactly turned that Vector front in to a kit but I could make some. It is a nose graft I did after an inverted "landing" when I flew through the sun. I'm actually going to cut one for a friend this week so it would be easy to make a few of them. I had to have the plywood made for me an entire 4x8 sheet. Send me PM if you wish and I'll send my email for better communication.
Offline Daniel_Munro
« Reply #12 on: February 09, 2022, 11:01:51 AM »
Here is a picture of how I installed everything in my Vector.
NZL7396
« Reply #13 on: February 09, 2022, 01:38:45 PM »
That is a pretty cramped nose.  Are you sure you are getting enough air over the battery?  It looks completely blocked in on one side.  You might consider Mark's scoops.
