  • June 15, 2025, 12:33:41 PM
Author Topic: Program Card ???  (Read 715 times)
Offline John Tate
Program Card ???
« on: July 21, 2010, 03:40:36 PM »
The Program Card by Arrowind only gives me the display of “READ”. It never goes to the next display. I have tried it on two different ESC’s, motor and battery sizes with the same results. Does anyone have experience with the Program Card that can help me out?
Thanks in advance.
John Tate
Re: Program Card ???
« Reply #1 on: July 21, 2010, 04:44:26 PM »
Thanks in advance.
John Tate
Yes John, I have used the card, problem is I do not have one with me to walk through it, so we'll try plan B
* First off I am sure you have it connected correctly (polarity of connector) Ask me how I learned about that....
* It is READing the ESC, I think you need the proper initiallizing button.  I think it is just the DOWN arrow button, but it might be the R/W button
* After it initializies it should switch to the number 1 then show the value in that register, use the left & right arrows to change the setting, then use the DOWN arrow again to call up the next number and register.
*   Keep walking down through the nubmers and re-setting the values as you wish them to be.  Final step is to push the R/W button (read/write) it should show that it is writing (saving) yur new settings.
* Disconnect and go fly...
Keep trying & writing, I'll be home in a couple days and can try it again live....
Offline John Tate
« Reply #2 on: July 21, 2010, 07:15:39 PM »
Dennis.
Thank you. I will play with the card and try to figure something out.
John Tate
