  • July 18, 2025, 12:56:49 AM
Author Topic: Flat ribbon on Hubin timer?  (Read 1340 times)
Offline Matt Brown
« on: June 11, 2018, 04:03:16 PM »
The flat ribbon cable for the fine adjustment pot is not cooperating with me. Is it just a basic cable that I could replace with a double ended female servo type cable? Being a flat rather stiff cable makes it difficult to position the timer where I want it.
I’m 95% sure I can safely swap it but sometimes there is more going on than meets the eye in electronics.
Thanks, Matt
Looking in the SV11 instructions, there is a picture where the fine adjustment pot is connected via a servo style cable. I’m going to assume it’s just a basic cable connecting the pot and timer.
« Last Edit: June 11, 2018, 06:31:29 PM by Matt Brown »
Online Crist Rigotti
Re: Flat ribbon on Hubin timer?
« Reply #1 on: June 11, 2018, 09:28:46 PM »
Yeah, I replaced mine with servo wires.
Offline John Rist
« Reply #2 on: June 11, 2018, 10:03:34 PM »
I'm pretty sure it's just a basic cable and connector. I had the same problem. Don't know why he had to put it 90 degrees. Makes it a real space hog. BTW that adjustment pot is something I've never used because it's just too easy to program the chip the regular way. I would just cut the tines off and encase the nubs with JB weld.
Is JB weld conductive?
Offline Fred Underwood
« Reply #3 on: June 11, 2018, 10:06:13 PM »
Fred
352575
Offline Walter Johnson
« Reply #4 on: June 13, 2018, 07:42:26 AM »
I was able to carefully/slowly bend the male pin connectors on the timer to vertical then just velcrowed to inner right fuselage wall. Walter
Take a spin.....You might like it.
