  • July 20, 2025, 05:31:53 AM
Author Topic: Flat Foam Build for Electric CL  (Read 1154 times)
Offline Jim Moffatt
« on: February 27, 2010, 02:25:52 PM »
Here is a 1/2A project that I am working on, 25" wing span. It will be flown as a CL plane but with RC control.
This type of kit is extremely easy to build - like a SIG Skyray. It needs some strengthening since it was designed as a slow flyer. But adding balsa doublers to fuse and wing will make it strong enough for the higher CL air speeds. I have flown this type of plane sucessfully on a 35' line. Its electric only since the foam would be destroyed by gas.
Target weight is 9 oz.
First pic shows The kit pieces
Second pic shows it ready for assembly.
I will use the Baby Clown power system previously posted.
I plan to add pix of the completed plane in several days.
« Last Edit: February 27, 2010, 05:40:37 PM by Jim Moffatt »
Offline bfrog
Re: Flat Foam Build for Electric CL
« Reply #1 on: February 27, 2010, 03:25:48 PM »
Jim,
I'll be interested to know how it flies. I built something similar a couple of years ago and it flew OK. It didn't like to loop very well because of the flat wing.
I don't understand what you mean by CL but RC controls. What does that mean?
Post results when you get it flying.
Bob
Bob Frogner
Offline Igor Burger
« Reply #2 on: March 02, 2010, 02:14:08 PM »
Bob, and what is the problem? too heavy? or? ... this video was here several times, but I am posting again, flat wing can fly as well ...
Offline bfrog
« Reply #3 on: March 02, 2010, 07:46:22 PM »
Igor
I think it was a matter of being underpowered. It was one of my first attempts with electirics bit I learned from it.
Bob Frogner
Offline Mike Palko
« Reply #4 on: March 02, 2010, 08:03:15 PM »
Watch some of the F3P videos and prepare to be amazed. :o
Offline Jim Moffatt
« Reply #5 on: March 03, 2010, 08:58:28 AM »
Igor's video was the inspiration for building and flying planes like this. A picture of the completed airframe is attached. It is flown with flaps coupled to the elevator. I will start another thread on it after I have it flying.
I have previously posted these links but here is how its twin flys around a camera tripod on 20'. Loops are about 12' in diameter:
And here are the setup details
