  • July 19, 2025, 05:55:02 PM
Author Topic: Powerlab 8 charging station case options, DIY?  (Read 1005 times)
Online Brent Williams
« on: December 11, 2018, 03:32:33 PM »
So here is a question to those that are using a Powerlab 8 charger, 2x HP DPS-600PB server power supplies, and a MPA 6 position paraboard.
- What are you guys using for a carrying case to house your charging gear?  I need to build, buy or modify something that will work for this purpose.
Online Fred Underwood
Re: Powerlab 8 charging station case options, DIY?
« Reply #1 on: December 11, 2018, 04:05:20 PM »
I used a small Pelican case and a shoe horn to get everything in.  See below about midway down.
https://stunthanger.com/smf/gettin-all-amp'ed-up!/power-supplies/
There are a lot of examples in the RC forums to look at, then DIY for fun.
IIRC, I used a Pelican Storm 2100 and there is now a Harbor Freight case a little larger and a more reasonable price.  I didn't look closely at them, but HF has the Apache line.
https://www.harborfreight.com/3800-weatherproof-protective-case-16-516-in-63927.html
« Last Edit: December 11, 2018, 07:24:49 PM by Fred Underwood »
Fred
352575
Offline Jim Mynes
  • Chelsea, ME
« Reply #2 on: December 11, 2018, 06:35:01 PM »
Many of the guys on RC Groups are using a Ridgid tool case, available at Home Depot, with good results. I had a Pelican case laying around so that’s what I used.
I have seen the light, and it’s powered by a lipo.
Offline jfv
« Reply #3 on: December 12, 2018, 07:26:49 AM »
Here's mine.  Pelican case with 2, 12v - 72 Amp power supplies wired in series for 24 volt output.  A bit heavy, but I often bring to the field for contests and hook up a charging station for participants.
Jim Vigani
