  • July 16, 2025, 05:50:47 AM
Author Topic: Fiorotti Timer  (Read 3362 times)
Online Motorman
Fiorotti Timer
« on: April 10, 2016, 03:01:47 PM »
Want to hear from guys that use the Fiorotti timer. I just got one and the weather is preventing me from using it.
I've heard that prop blast helps you turn so, does the plane still turn good when the rpm cuts down?
Does it boost and cut in the right places or does the lag screw you up?
Does it use more battery power?
I guess I'll find out soon enough but it would be nice to have a heads up on any quirks.
Offline Rogerio Fiorotti
    • Control Line by Fiorotti
Re: Fiorotti Timer
« Reply #1 on: April 12, 2016, 03:39:31 AM »
Hi Motorman
In the USA only three people are using my timer.
Fred Underwood
John Tate
Richard Hart
Fred has questioned enough and already has several flights is the right person for the feedback.
You read the email I sent?
Rogerio
Online Motorman
Re: Fiorotti Timer
« Reply #2 on: April 13, 2016, 06:20:23 PM »
I think you need to re-write those instructions so the average dummy like me can understand them.
From the manual:
2- To change the programming you have to wait until the long blinking referring to the function you desire to  change and keep START pushed while the LED informs the setting recorded until the blinking sequence starts and then release START
Re: Fiorotti Timer
« Reply #3 on: April 13, 2016, 06:43:46 PM »
To change program wait for a long blink corresponding to the function you want to change, then keep START pressed while the LED informs the value set until the blinking flashes, then release START switch.
Complicated ...... but I'll be recording a video that shows how easy it is.
Rogerio
Online Motorman
Re: Fiorotti Timer
« Reply #4 on: April 17, 2016, 03:49:23 PM »
I'll be looking forward to that video.
Offline John Tate
Re: Fiorotti Timer
« Reply #5 on: April 18, 2016, 06:25:35 PM »
Motor Man.
The instructions to setup the Rogerio Fiorotti timer was a problem for me at first.
After a few emails with Rogerio and a couple of other modelers around the world, I was able to get the timer to work to where it was usable for me. First, you need to have a Castle ESC hooked up the Rogerio Fiorotti timer. My main problem first was that I tried a YEP 40 ESC and a Turnigy dlux 40 ESC and I could not get the RPM's to set. I tried to set the RPM's at the lowest and to the highest but the RPM's only stayed at one setting. Once the Castle ESC was used then I could set the RPM's any where I wanted it.
Today the wind was down to 5 to 7 MPH here on the east coast of Virginia.
So I went flying with a Vector 40 converted to an Arrowind 2820 motor, Castle Phoenix IceLite 50 ESC and the Rogerio Fiorotti timer. A 2200 MAH, 4 cell battery was used. The level lap times were at 5.1 seconds. The accelerometer, (sensor), would detect when the Vector started a climb such as the wing over, loops and so on. The Arrowind would speed up when needed and carry the Vector through all of the maneuvers. The flight time was set for 5 minutes and 20 seconds. I checked the battery at the end of the flight and each cell readings were as follows: Cell # 1 = 3.75, Cell # 2 = 3.74, Cell #3 + 3.75 & Cell # 4 = 3.76.  If I remember correctly: The battery had more in it verse the other timers that I used in the past. I let the motor cool off and put up another flight and everything was the same as the first flight.
I enjoyed flying with the Rogerio Fiorotti timer in the calm wind today.  A couple of months ago I went out and flew the Vector on a 15 MPH day. I learned that the accelerometer, (sensor), does detect any movement of the airplane (as it should). So on a windy day, the Vector was pushed around and the accelerometer will give you feedback on how windy it is. The motor would change RPM's when it needed to fight the wind. Doing loops on a windy days does changes your timing from what you are used to doing at the handle. Like using any new equipment, you need to learn how use to it.
Online Motorman
Re: Fiorotti Timer
« Reply #6 on: April 18, 2016, 07:06:12 PM »
I have the CC edge 50 on my Banshee and I re-programed it for the Fiorotti V3. I didn't program anything new on the timer 'cause I didn't want to screw it up.
I took a flight, no stop watch or anything just wanted to get a general impression.  Take off was fast and level flight seemed a little fast but I've got a stout prop on it. Pulled up for a wing over and the motor changed speed cool, tried some loops and it gave me power at just the right spot. This Banshee never flew good, now it flys great, if can you believe that,  I LOVE THIS THING! want to buy 2 more. All I have to do is program for more flight time, everything else is perfect.
Offline John Tate
Re: Fiorotti Timer
« Reply #7 on: April 18, 2016, 07:24:11 PM »
Motor Man.
Once you get in a few flights then you will want to tweak it a little to make it perfect.
Online Motorman
Re: Fiorotti Timer
« Reply #8 on: April 19, 2016, 12:03:24 PM »
John, What did you end up tweaking on yours? Did you find you could make it too sensitive or make it come on the power to hard? What happens at the extreme settings?
I'm going to try and figure out the blinky blink adjustment system today, wish me luck.
Offline John Tate
Re: Fiorotti Timer
« Reply #9 on: April 19, 2016, 06:28:30 PM »
I did the tilt the nose down once and brought it back to level to get the lap time to where I liked it. I changed the gain to where it was comfortable for me. I am still experimenting each time I go out to the field.
